Just digging this up to add that you can obviously flow test your own injectors, perhaps not as accurately as a dedicated test rig and not at service pressure but:
The feed port sans oring/support washer fits nice and snug into standard 3/8" EFI fuel hose, clamp it if you like. Then all you need is a pressurised supply of your chosen fluid (eg injector cleaner). I just used a length of hose sprayed full of degreaser with my air gun jammed in the other end with a gentle trigger finger, but for ten I'd bother building a manifold with a fluid container (think old sealed oil catch can or so)
Then you need to trigger the injectors. I bodged up some croc clips to 4?mm spade terminals from Jaycar (heatshrink mandatory if noninsul) and jammed them on by hand (bit fiddly but gets easier by injector 3...). Pin 2 is ground (not that I think it matters). Then supply 12V. I used an old AA NiMH charger plugpack, which had the lovely side effect of voltage sagging as the piezo activated just enough to shut off the injector, giving me about a 20% duty cycle by default.
[Edit] if your injector gets hot stop, disconnect. Seek another power supply. I started out using a car battery charger, too much amps obviously.
Last thing you need is a measuring cylinder and a stopwatch. Obvs more than one if you do them in parallel, but do say 3 runs per injector and I doubt your errors would be significant if you run them for a minute or more doing it sequentially.
The only thing a machine does different us automate much of the process and have neat/easy connectors to save time and avoid mistakes when used regularly. The "science" (*vom*) of the procedure is the same.
GTI V. Saving for wavetrac
