I going to join the dealer bashing......
Just took half my bloody boot apart on the Passat after knocking the rear wiper and thinking that I damaged/loosen something cos it didn't work anymore. Didn't think it would be that fragile.
Then i realised that I haven't used it since it got serviced on Monday and I decided to check the coding of the steering wheel module.
Turns out the for some reason the dealer set the code to "sedan" setting with no rear wiper
(I had my original code from when I was installing the bluetooth, as reference).
VW dealer of the year my butt
2008 Passat 3.2 Wagon |
2002 A3 1.8T | APR Stage 1| APR Downpipe | APR dogbone | Diesel Geek Shifter | TT pedals | Forge DV | Saikou Michi OCC | NewSouth Boost Gauge | AVUS Rims | Whiteline Rear Swaybar & ALK | N75J | BMC CDA | APR TIP & TB Hose |
