is there a question in that?
if you want you could always remove the Goop & compressor and replace it with a space saver
just an idea if it really conserns you
but it is a bit of a catch 22
remember tho that in the case that you get a flat and have to use the goop your tyre will end up coming off to be repaced or repaired anyways in which case the sesor could be cleaned?
