wierd
So some ECU hardware fails once the car has gone beyond 100kms hmm I am thinking not. Probably just some adaption type of issue that they will limit with an upgrade. At least remapping these things is quite quick and easyToyota says the problem is not mechanical, and that the ECU’s software will need to be re-mapped (or “re-flashed” in car jargon) if it has less than 100 miles on the clock. It says that if the odometer reading is higher, the ECU should be replaced.
