Agree with you on the paragraphs in post #1 ... amended accordingly.
It appears to me, and journos have noted also, that the slightly softer front end springs has the front end leaning more heavily on the outside front corner on corner entry ... sort of like when guys add a rear-only only sway bar to their GTI.
Once a turn into a corner has commenced, the weight starts to shift from the front outside tyre to the rear outside tyre to a degree ... this then activates the stiffer rear end springs & the rear sway bar that counters the rear-end body roll by twisting & transferring load to the inside rear wheel ... this in-turn causes causes a slight imbalance with the rear end slip. It helps point the Coupe into a corner more aggressively ... as does a rear-only stiffer sway bar on a GTI.
The yaw slip is only momentary. However, once you get on the power and cause the rear torsen LSD to apportion power from inside wheel to outside rear wheel in concert with the stiffer rear end end causing some slip, you do have a the rear move around for short moments causing a loss of overall balance and front to rear grip. This requires a bit more effort on corner entry and patience when applying power exiting a corner and makes the drive more challenging imo.
Having rear MOTOR Mag BFYB Shoot-out earlier today, I agree with the comments made that the Toyota would be tad more difficult to extract the best from with that slight inherent inbalance on corner entry due to rear end slip. Wakefield Park is a tight circuit that requires good turn-in, so the Toyota FT86 did quite well.
On a faster more flowing circuilt like Eastern Creek, I'd put a five spot on the BRZ as being the quicker of the two in that it should be able to hold that neutral balance for longer on the longer & faster sweeping bends, rather than see-sawing front to rear that with the front & rear fighting each other for outright grip.
I prefer the look of the interior of the Toyota FT86 GTS with better SatNav radio and Carbon Fibre treatment. The Subaru has the data dots and full alloy spare with imo is a must for country/interstate touring. Subaru is the better looker in the exterior dept imo esp with spoiler. I'm on the list for a drive in the BRZ to compare it against the FT86 Coupe.
WJ
