Results 1 to 10 of 13
Thread: G-Tech pro Fanatic RR or others??
    Jan 2009
    Hi, I'm chasing input from people who've had experience with the g-tech pro fanatic. I'm really only interested in lap times and segments rather than the other features which accelerometers provide, which means the RR version rather than the SS version is needed.
    I'll also likely be getting an iPhone shorlty and reading a little about the Dynolicious app, which from what I can tell doesn't provide lap times. Any other apps worth researching? I have an android tablet, so that could also be an alternative if an App would suffice.
    Sean
    Daily: 2010 VW Jetta Highline
    Mar 2009
    UMG Brisbane
    I was looking around for these on the weekend, and not having much luck.
    Since found these:
    iOS
    App Store - Harry's LapTimer Pro
    Android
    Trackmaster - Welcome
    2013 MY13.5 Passat V6 Highline Wagon. Watch this space
    GONE:2017 MY18 Skoda RS169 Wagon w/ Tech & Lux, 2007 VW MKV Golf GTi
    Feb 2007
    Brisvegas
    Hey there, I currently have the SS model and think it's a pretty cool bit of kit. Functionality wise I mainly use it for 0-100 times now because the quarter mile function and the peak HP and torque function require a straight flat "private road" because of the speeds you will hit to complete the function (ie revving out 4th). But now I'm enjoying more circuit work for the first time I will probably go for the RR upgrade SD reader for lap times. Then the cornering G force readings will come in handy too.
    The unit itself is easy to use and attach, and It never really goes below 8 satellites in connection at one time (out of a max of 12) so I guess the accuracy is pretty good.
    Hope this helps!
    Nov 2009
    As above, I have the SS too, and have had lots of good experiences with it on several cars. Only downside is that it takes forever before it gets a decent lock on a large number of satellites. I usually need to make sure it's been running for at least 5 mins before I take off.
    Not done any track work in my car myself, so didn't bother going with the RR expansion. I do suspect, however, that it'd be far more accurate than any iPhone app.
    Jan 2009
    Thanks for the input guys. I've had a closer look at the trackmaster app, it looks pretty awesome, though they recommend running an external GPS for much improved accuracy, increasing from 1hz which your phone would do to 5 hz (so recording data at 5x per second rather than 1). If I can get the tablet (or Iphone) to pull that GPS signal from my pioneer headunit/GPS, I may be in luck, not sure if that's possible or if the headunit records at 5hz. Looking at ~$100 for an external GPS, in which case I'd spend the money on the g-tech to do it right the first time.
    1hz is pretty useless and can't be particularly accurate.
    Nov 2009
    Quote Originally Posted by seangti View Post
    Yup, absolutely. 10Hz minimum for acceleration testing, 5Hz for track work I reckon.
    Jan 2009
    Quote Originally Posted by AdamD View Post
    Thanks Adam. I'm nearly sold on the G-tech being the best tool for the job. Value for money, etc.
    A bloke I used to work has a Vbox Lite - http://www.racelogic.co.uk/_download..._Lite_DATA.pdf, phenominal piece of kit, but expensive (~$1900 I think). It's on his race car, so warrants something a bit more serious.
    Nov 2009
    I have a feeling you can pick up a new VBox (there's a basic stripped down version for your average Joe - not sure if that's the "Lite") for around the $500-600 mark via eBay - that's what I saw when I was researching. Not sure of the features available to support track work though - I was focussing on outright performance testing only. The VBox is used by many professional motoring magazines and is generally considered to be the benchmark product, but their cheaper offerings are only 5Hz or 10Hz, like the G-tech, and still command a premium!
    Edit: Here we go, the 10Hz VBox Mini: http://www.vboxaustralia.com.au/vbox%20mini.html
    Quote Originally Posted by VBox
    It is ideally suited for performance testing, lap timing and long term durability testing. However, this unit is not recommended for Brake testing.
    Jan 2009
    The Vbox (PerformanceBox) mini looks good, though is pushing $600. Getting a little serious for my purpose.
    Jan 2009
    Well I've order the GTech pro RR. Should have it by end of week. Have lakeside next weekend and QR end of July to test it out.
