Another great day out at Queensland race on the national circuit.
Some data from the day
Lap times
Max Speed 173.83
Lateral G's: 0.55 to -.52
Longitudinal G's: 0.39 to -.96
Last time out on the Clubman circuit with very cold air temps my acceleration speeds was quite a bit higher down the back straight and start finish line. I'd say that shows the difference in air temp between the 2 days and the heat soak I was experiencing with the factory side mount intercooler. When on the clubman circuit, air temp mid single digits, y'day at QR was high 20's. My corning g's are near identical. There is a consistent trend that with a slow/cool down lap prior, I was carrying 2-3km/h more over the start/finish line.
Clubman Details
max speed: 178.27
Lateral G's: 0.57 to -.48
Longitudinal G's: 0.37 to -.93
When time permits next, I want to do some in gear power runs in 2nd, 3rd and into 4th to best gauge ideal shift points. I usually shift around 6000rpm - 6200rpm, rarely ever going above that and using 3rd and 4th gear only at QR and lakeside. Neither circuit require 2nd gear and will still spin through third gear with a little steering lock.
