Run the heater, direct the hot air onto the windscreen. Fog only forms on the inside of windows when they're cold (the moisture in the air condenses on the cold surface).
Hi all,
my a/c compressor finally shat itself and I don't intend on forking out the money to repair until the end of winter. That being said i'll be constantly competing with a foggy windscreen, I haven't done much research but before I do; does anyone have any recommendations to reduce fog in the windscreen?
Thanks!
Nothing to see here...
Make the inside of your car hotter.
Use your imagination on methods how![]()
2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
I had the impression that heat is what makes it fog... hhmmm, Ill give it a try, thanks boys!![]()
Just FYI, cool (not cold) air on the inside of a windscreen during winter will keep it fog free FAR BETTER than hot air in winter. Keeping the inside glass temperature as close to the outside as possible is how to avoid fog.
I believe there is something being researched for this at the Proton collider in Geneva...
