Originally Posted by
Lucas_R
Symptoms that you have a failing tensioner or a stretched cam chain will be rattling on that side of the engine. Obviously if the chain gets loose enough that it either comes off the sprokets or snaps then its going to cause the engine to go out of time and cost a lot of money to fix.
If you can hear some noise in that area then its probably something you want to look at getting replaced in the next 6-12 months or so just in case. You say its quiet - so it sounds like there is no need to rush to have this replaced. Also the EA113 is quite a noisy (ticky) engine at idle anyway, blame the direct injection system.
A lot of this wear and tear can be reduced with more regular oil changes. I know people think its great that new cars only need an oil change every 15,000km but in reality this is too long and causes premature wear on timing chains/guides/bearings etc. Obviously when people buy these cars 2nd hand with 80,000-100,000km they face some of these symptoms of too-long service intervals quite quickly.
