Page 78 of 85 FirstFirst ... 28687677787980 ... LastLast
Results 771 to 780 of 842
Thread: DSG woes in The Age
  1. #771
    Jul 2011
    Been a R36 I would assume you have the 6sp Wet Clutch which has not been recalled.
    There has been a very small number of problems with these gearboxes (clutch shudder, mechatronics issues) but nowhere as big as the 7sp dry clutch which is why they were recalled.
  2. #772
    Sep 2010
    Thanks for the clarification lads .. read about the DSG DQ200 but wasn't sure if that was the 6 or 7 speed
    Quote Originally Posted by nomadx38 View Post
    I have noticed mine on the odd occasion when its cold that 1st to 2nd is pretty rough. One time it actually had a pretty loud bang on upshift. Has been the only thing so far that has warranted any concern. Will need to get it looked at on next service
  3. #773
    Jul 2011
    The gearbox numbers are in order of the amount of torque they can handle.
    Dq200 (250nm) - polo, jetta, golf
    Dq250 (350-400nm) - golf GTI/R and most diesel models
    Dq500 (500nm) - Tiguan, Multivan
    Banging could be caused by the calibration been out (as they sometimes tend to do) or that the oil has started to break down and the viscosity has changed from the original spec causing it to be a bit thick (or too thin) when cold caused by normal operational usage.
    How many km have you done? I know at 60,000km they replace the gearbox oil and filter for this reason. If its only doing it at start up or a little bit I wouldn't concern yourself as much. If it does it every gear change/take off I would be getting it looked at.
  4. #774
    Sep 2009
    Mel, VIC
    hi there,
    my golf 118tsi with DSG was bought brand new in 2010 which falls in the recall range, so far it's ok except two potential problems
    1. car is shuddering at low gear
    2. shuddering noise after hot start(restart the car after parked for a while). noise last few sec then gone.
    not sure if it's from clutch or gearbox, do u guys think i need to call 1800 number? or just wait for the recall letter
    because apart from that, no prob at all.
  5. #775
    Sep 2010
    Ahhh ok thanks for that. Good to know
    32,000kms. Yeh I haven't worried "too" much about it since it happened as it's a rare occurrence. I still will mention it when I get it serviced. Due for my 3 year now.
    Speaking of servicing and without going too off topic - has anyone taken their car to Volkwerke in Greensborough (VIC)? I've taken the car to the dealer for both services (bent over both times) but thinking of going there from now on.
  6. #776
    Jul 2011
    Quote Originally Posted by roy View Post
    hi there,
    Hey man,
    The shuddering in first gear is the clutches. Pretty easy fix and well known about. Just demonstrate the suddering to the dealer as they will replace it.
    With the rattling you "could" have the same issue as on the Polo GTI's (as they use the exact same twin charged engine) the rattle comes from a fault in the camshaft positioner for the VVT. It rattles for 2-3 seconds after the engine is started. It would be a good place to look.
  7. #777
    Jul 2012
    Audi recall and Skoda recall now up on the Recalls.gov site.
    Audi has the A1 and A3, Skoda the Octavia and Superb.
    No real surprise there.
  8. #778
    Quote Originally Posted by ill0gitech View Post
    No Fabia?
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
  9. #779
    Jan 2013
    Melbourne, Vic
    Alex, from what I can gather the problems were 'fixed' before Fabia's starting to come to Australia. Boy I really hope that's the case since I pick up my new one is a month or two.
  10. #780
    Quote Originally Posted by Bradpalace View Post
    Well for your sake, I hope so! But hasn't the Fabia been here for a while now?
    Alex Aescht
