Originally Posted by
logger
The DSGs have issues, however in regard to
Both wrong ....
1. The 7 Speed gearbox mechatronic unit, which is the most effected of the two main DSGs, contains no gearbox oil. 6 speed does though.
2. That's pure speculation. I could also speculate that adding a second clutch would double the combined clutch life, when clearly it does not. The cars characteristic of running taller gears is by design and does not mean it has a tendency to "ride" the clutch. I have seen no clear evidence off the taller gear regime being the cause of the DSG7 clutch failures.
