Page 56 of 85 FirstFirst ... 646545556575866 ... LastLast
Results 551 to 560 of 842
Thread: DSG woes in The Age
  1. #551
    Dec 2008
    Sydney/Canberra
    He's got a point though.
    You're kidding yourself if you think you can drive a DSG-equipped vehicle the same was an automatic. Sure, they have the same amount of pedals, and the gearstick looks pretty much the same, but everything you know goes out the window when you stab the throttle to make a quick getaway, leaving you the same effect as giving a manual car a gut full of revs, and dropping the clutch.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  2. #552
    Jan 2012
    Quote Originally Posted by markwid View Post
    I say that is a bull**** theory...
    This is a consumer product, you don't blame the consumer for using the car normally. Heavy stop/start traffic is common occurrence in any large city.
    So if the DSG is not designed, and built, to withstand such normal use, what good is it?
    Agreed but he does have a bit of a point. I think the hard thing is that you can't modulate the clutch. Which means you don't really know how much the clutch is actually being used in a DSG equipped vehicle.
    TRADED THE BEE'12 Sport Yellow/Black Citroen DS3 DSport THP155 6-spd manual w/ tech pack.
    SOLD '18 BMW 125i M-Sport | Sunset Orange | Sunroof | ZF 8-spd auto
    '23 MINI Countryman SE ALL4 PHEV | MINI Yours | BRG
  3. #553
    Trinidad and Tobago
    DSG woes in The Age
    Anyone blaming the consumer for how the dsg is driven in traffic is missing the point. Why?
    VW does NOT tell the consumer anything about driving it differently than any other automatic transmission.
    If it was down to how consumers drove in traffic being te cause of issues then why doesn't the dq250 suffer the same issues in heavy traffic on the scale of the dq200?
    The consumer has no control over the clutch slippage for the most part. It is the last thing on their mind.
  4. #554
    Some people can drive a manual car and not need to replace the clutch in 150,000km+
    Another driver in the same model car will need a new clutch in 50,000km and blame the car
  5. #555
    Jan 2011
    Brisbane - QLD
    Quote Originally Posted by wai View Post
    Well, if it is cooling the oil, it is a simple matter of adding an oil cooler attached to the radiator.
    The other thing from this is that you DO NOT CRAWL.
    dq250 in my gti and dq500 in my tiguan both have dsg fluid cooler above the gearbox fr factory.
    MINI Cooper S Clubman - FWD
  6. #556
    Trinidad and Tobago
    DSG woes in The Age
    Quote Originally Posted by nat225 View Post
    This is what I like to see. Actual facts from owners as opposed to pure speculation. By the way does your manual make reference to dsg overheating for either the dq250 or dq500?
  7. #557
    Jun 2011
    Sydney NSW
    The point I'm making is that it is not consumer ready the way it is being sold. It has been released before all the issues have been worked through. Buyers are treating it like a normal automatic gearbox, and it is simply not suited to it. This does not make the buyers wrong as it has been sold as an "automatic".
    Now that it has been released, it is up to VW to rectify things.
  8. #558
    Jun 2011
    DSG woes in The Age
    whereas the European chainsaws are dainty units that will fall apart if not treated with kid gloves.
    VW must be relatively confident in the design / robustness of the DSG in the R, given they also give you Launch Control to play with...
    Golf R | UG | DSG | 19" Silver | ACC | Leather | Viezu vRace | FIS+ Advanced | View car diary thread
  9. #559
    Jun 2011
    Sydney NSW
    If the transmissions are failing because of overheating and they already have an oil cooler, then they need a bigger one. If they don't have one, then they need one.
    Unfortunately fitting an oil cooler is not simple as the pump has to be able to pump around the longer circuit. It may need an electric pump.
    One of the issues raised has been that when crawling in traffic, there is insufficient air flow over the mechatronics unit to dissipate the heat. It may need a fan or ducting from the existing radiator fan to help with cooling.
  10. #560
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by Rawcpoppa View Post
    except when it is you doing the speculation it seems
    I think you're right about heat and shift patterns being the main issues for a dey clutch dsg......
    ...WRT Mechatronic failures..If I had to guess I would say it might be heat related, hydraulic valves being worn ?
    But I do agree. Sticking to the facts and not speculating is the way to go. There is link earlier in this thread to a Singapore sourced article. In it VW are quoted as saying there was an issue with sulphur in the Dsg7 Mechatronics hydraulic oil reacting and breaking down with plastic parts of the the electronic circuitry. Resulting in short circuits. In singapore they recalled and replaced the mechatronics unit with a revised version.
    AFAIK this has not been done here in Australia yet. Now if I was to speculate......
