Page 50 of 85 FirstFirst ... 40484950515260 ... LastLast
Results 491 to 500 of 842
Thread: DSG woes in The Age
  1. #491
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by alexaescht View Post
    Actually, the 7 speed DSG does have gearbox oil....
    It does. However Re read my post. I said the mechatronics unit does not contain gearbox oil not the gearbox. The seven speed mechatronics unit has it own independent oil circuit containing hydraulic oil, not gearbox oil.
  2. #492
    Apr 2011
    Sunshine Coast, QLD
    Has anybody called the Customer Care Hotline?
    I did yesterday. Was told my car had no issues, but please make an appointment with the dealer of my choice to get the car inspected. Why then, I asked, were recalls happening overseas? Why weren't they addressing the problems here? Sorry, VW Head Office are not telling us either.
    Anyway, for those of you who say all marks have reliability issues, then cite a recall - Toyota is the example that comes to mind - there is a big difference. Toyota was proactive, protecting the owners AND maintaining confidence in the company, and hence their brand's value (read resale prices).
    In contrast, VW is reactive - and has taken much too long to address people's concerns:
    “Organising a recall is a complex process. It involves communication with local government authorities, legal framework and the organisation of spare parts and servicing,” a Volkswagen spokesman disclosed, adding, “We are aware of the situation in Australia. We will react to the complaints. It will go beyond a service action.”
    What I don't get is why some people on here are still saying that this is overblown, that there is no proof, that the problems of a few are hurting us all, there is no evidence. What do you call the recalls overseas? What do you make of this about-face by VW?
    Sure, the problem may only affect a few cars, but why not just sort it out then??? Why the big drama and the silence???
    Personally, I am relieved that VW is finally acting, because if there is any chance of regaining some confidence in the company, this is the necessary step.
    (PS: I am also perplexed by 2 or 3 other members being overly critical of VWOzCrap. He may have a history, but he wasn't being particularly offensive or difficult in this thread. And he now certainly appears vindicated. He deserves an apology. The treatment he received was pretty shameful, and I'm surprised those members weren't sanctioned by the mods. But I guess those 2 or 3 members got what I feel they deserved in the end, because they drew a lot more attention to VWOzCrap's posts than would have been warranted otherwise...)
    2011 Polo GTI | Black | 5 doors | Comfort pack | Audio pack | 9w7 Bluetooth | Xenons - a Return to VW!
    Previous ride: 2008 Mazda2 - ZOOM-ZOOM indeed!
    1st Ride: 1988 Red VW Fox Sedan!
  3. #493
    Jun 2011
    Sydney NSW
    Well, I'm not sure they are "finally acting". Despite the Caddy also having the problem gearbox. it does not look like they are going to do anything about the Caddy. The problem is that commercial vehicles with the issues are likely to be more of an issue that those owning passenger cars as their vehicles are used to earn their livelihood.
  4. #494
    Quote Originally Posted by RoknRob View Post
    Aren't the big Toyota recalls the ones that may end your life if not resolved? And if initiated from the USA then they may be safety recalls called on by a Government authority. Remember the unintended acceleration story that swept America a few years ago. At the time it did damage to Toyota's brand in the USA.... and it ended up being driver error or misfitted carpet mats.
    There are whispers that Ford Powershift (dry clutch) is suffering from the same problems as the DQ200 box. Shuddering on takeoff, missing gears/false neutrals, weird noises as it changes gears.
  5. #495
    Quote Originally Posted by logger View Post
    Both wrong ....
    1. The 7 Speed gearbox mechatronic unit, which is the most effected of the two main DSGs, contains no gearbox oil. 6 speed does though.
    2. That's pure speculation. I could also speculate that adding a second clutch would double the combined clutch life, when clearly it does not. The cars characteristic of running taller gears is by design and does not mean it has a tendency to "ride" the clutch. I have seen no clear evidence off the taller gear regime being the cause of the DSG7 clutch failures.
    Actually, the 7 speed DSG does have gearbox oil, it's just that the clutches aren't bathed in it, only the actual gearing and mechatronics are. Just like a manual gearbox has a dry clutch, but still requires gearbox oil.
    One of the major issues as I understand it is the dry clutch gearboxes when run in slow moving, stop/start traffic are doing a LOT of clutch slipping and the gearbox reaching temps of 400+ degC. So any electronics that is located close by (i.e. mechatronics) is going to get a good baking from the radiated heat from the hot clutch plates and surrounds. Electronics plus high temperatures = electronic component failures. The way electronics manufacturers work out Mean Time to Fail figures is to run their equipment at elevated temperatures (in an oven) to accelerate the testing/occurrence of failures.
    Taller gearing does require more clutch slipping to get the car moving smoothly. Just try taking off in second gear all the time - which is what the DSG box effectively does due to short-shifting first gear. Plus in slow moving traffic the fact that first gear does not re-engage until the vehicle comes to a complete standstill means that the DSG will slip the clutch otherwise you'd stall the engine.
    I'd say a lot of the issues with the DQ200 are heat related and can be attributed back to the push for the best in class fuel economy figures. Fuel economy may be great but if you destroy clutches in the process it costs a whole lot more than the 0.1l/100km saving you may achieve from running higher gears, upshifting early and slipping the clutch until the road speed picks up enough to have the clutch fully engaged.
    If VW modified the shift pattern of their DSG gearboxes, half their problems would go away overnight.
    Jun 2007
    Well I've just flicked an email to the local VW dealer.
    Back at the service in 2011 I was experiencing relatively frequent hesitation particularly around when the gearbox would normally shift gears (but sometimes wouldn't - it would falter and then continue accelerating and shift higher up in the rev range). I reported it, nought came of it back then as it is intermittent - can't demonstrate it, they don't do anything (and I get that, but I always make sure it is noted on my service invoice).
    Anyway, I'll see what they do with it now under their new 'campaign' (mine has the 6spd wet clutch). It's already going back for a full day diagnostic look at an issue I reported with second gear shift crunching (again, intermittent) so no skin off my nose to raise it again.
    07 Jetta TFSI | 18" Charlestons | Blue Graphite
  7. #497
    May 2013
    Qld
    Quote Originally Posted by pologti18t View Post
    There was few reports on fordforums that I read off, joined up to have a look as we were looking at a ford focus titanium diesel at the time.
    We drove one and it was hesitant off the line and jerked if I was hesitant with the throttle. This was probly my error as had driven a mondeo diesel previously and it was lag lag lag next thing you know it was like a driving a early 90's sierra cosworth all over again
    But I didn't notice any noises, the car was a dealership demo and had about 4k on it.
    One bloke lost a few gears on the highway and limped to a dealership.
    One of the syncho's on one of the gear dislodged itself and started making popcorn inside the box. car had like 10k.
    I remember the same thread some bloke was complaining how he found it irritating that his focus would downshift especially on downhills with the cruise control on
    "But my Nissan or Mitsubishi never did it"
    There was a couple of reports of shuddering/noises between gearchanges and one guy took his focus to ford and they just showed him some print out operating characteristics of the gearbox e.g all the noises it makes, how it acts.
    But I asked the sales bloke about that and he said that there was a new flash available but was more done if people mentioned shudders etc...
    anyways time for a giggle
  8. #498
    Apr 2011
    Sunshine Coast, QLD
    I consider an unexpected loss of power - such as a "false neutral" - a potentially life threatening event.
    Since the government here is unwilling or unable to oblige car makers to do the right thing, and VW wasn't about to, of it's own volition, well, (I can't believe I'm about to write this) thank goodness for the media, then.
  9. #499
    Adelaide hills, SA
    I don't think it's the medias job to worry about resale values, etc.
    I said that the resale values don't come to their mind. It's good to see that we both agree
  10. #500
    Trinidad and Tobago
    DSG woes in The Age
    I think you're right about heat and shift patterns being the main issues for a dey clutch dsg. The juddering I have felt only occurs when the car is in gear 2 and attempting to pull off from low speeds (that I would think gear 1 should be used for) usually under strain like moving uphill or a few occupants in the vehicle. This is only in D mode where the dsg shifts to gear 2 quickly from gear 1 at about 1400-1500 rpm. It feels like trying to accelerate in a manual car in too high a gear (the juddering effect) and I suspect that is exactly what's happening. This doesn't happen in manual mode nor sport as the dq200 won't let you shift out of gear 1 before 1800-2000rpm.
    With respect other it should be noted that the juddering I have experienced usually happens after being in city driving i.e stop start driving and lower speeds. The dsg is heating up basically.
    The higher the temperature the more the friction coefficient of the clutch changes (luk the maker of the dq200 has stated this) and it is more likely to judder as the clutches slip under strain depending on the gearing.
    All of this is from observation, Internet links, te service manager at the VW dealer here and the following is from my user manual for a 2012 Jetta:
    The DQ200 needs air flowing past it to cool down. I don't know what sort of traffic you guys encounter in Australia but think about someone who encounters long stop start traffic where they are crawling a lot. DQ200 temps will rise. It may not be passing the threshold for alarm set by vw but it can still be high. Day in day out this can lead to issues I would think seeing that vw saw it fit to put that notice in their manuals. You guys should point this out to the officials when you make your complaints as I think it points to a fundamental design flaw.
    Dq250 dsg is less prone to this high level of heating. Why? It contains a lot more oil that can take heat away from the clutches. Similar to how an automatic slush box has a lot of fluid that does the same. It's why you hear fewer complaints from gti owners (or any with the 6 speed wet clutch dsg)
    Edit:
    The juddering is a separate issue to the false neutrals and mechatronic failures some experience. I have no proof of what causes the mechatronic unit to fail. If I had to guess I would say it might be heat related, hydraulic valves being worn maybe?
    I think the DQ200 is a brilliant idea in that by using less gearbox oil for the clutches the efficiency of the 7 speed dsg is higher than even the 6 speed dsg and manual transmissions due to less parasitic power loss from the clutches moving through alot of fluid (oil). With that in mind though inherently dry clutches do heat up faster than wet clutches due to differences in heat capacities and friction which is why the DQ200 is limited to lower torque producing engines in the VAG line up. From an engineering standpoint the fact they can tell me to drive the car fast enough for air to cool the gearbox is a big fail in my opinion. Why? If heat is such an issue VW should have designed a way for the little bit of oil present to be cooled without driver intervention in ALL instances. An oil cooler taking heat away possibly would be a better design. It's not unheard of.
    Can owners with both 6 speed wet clutch DSG (DQ250 DSG found in GTI, Golf R etc, 2.0TDI, 2.0 TSI or larger displacement equipped VAG vehicles) and 7 speed dry clutch DSG (DQ200 found in many with 1.4TSI, 1.8TSI, 1.6TDI or smaller displacement equipped VAG vehicles) check their manuals for official VW references to DSG over heating?
