Not exactly. The proceedure is to test them, find out what the defective component is and the broken translation leads me to believe that the issue in generally with the solenoids inside the mechatronics unit.
It goes back through the re-work line and tested again. If it passes this time, it goes out. If it doesn't then back through again until all the solenoids are (supposedly) working correctly.
So I guess the simple answer is no.
