Page 9 of 85 FirstFirst ... 78910111959 ... LastLast
Results 81 to 90 of 842
Thread: DSG woes in The Age
  1. #81
    Apr 2011
    Sunshine Coast, QLD
    I think you've hit the nail on the head, GippsCC.
    It is probably that exact randomness that makes a consistent fault difficult to reproduce, therefore difficult to fix. The randomness is easily explained when one considers just how incredibly complex these units are!
    Which is why I think VAG is so reluctant to do a recall. Short of pulling the plugs on these engines/gearboxes, what can they offer?
    But to suggest the problems aren't real because they are not reproducible, in the face of overwhelming reports like the multitude on this forum , or the comments attached to the Fairfax article, is folly.
    VW stands to lose a lot of business if they continue to stick their collective head in the sand.
  2. #82
    DSG woes in The Age
    As Gavs has said before, VW need to replace all 7-speed dry-clutch DQ200 gearboxes with the 6-speed wet-clutch DQ250. They statistically have a much, much lower failure rate than the DQ200, and are smoother during operation. It would of course cost a heap of money for VW because of everything they'd have to do to make the different gearbox fit and all of the certification processes that would result, but hopefully the gearbox would be swapped to the DQ250 and from there on no further problems would arise.
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
  3. #83
    Jul 2011
    What my gearbox does is different to what most others do. In a way it's pretty unique to me (how lucky am I!!!) in that no one has seen it before and no one knows how to fix it. All I know if that the gearbox is NOT to blame but the information that is given to the gearbox from various sensors and electronics is - which isn't allowing it to properly match the engine speed (as it would seem) and as such drops the clutch quite frequently.
    No fault codes ever - many replacement of mechanics electronics - no fix! I don't blame VW for much but more R&D and In field testing should have been done to fix what is clearly a problem with the computer trying to understand infomation that it has never seen before or is out of range. These gearboxes are awesome and a technical marvel but I think the software that is required to run this has to be of a higher level than what "they" think is acceptable.
  4. #84
    AutoBahn
    Interesting: Direct-Shift Gearbox - Wikipedia, the free encyclopedia
    All of the countries listed are currently conducting a recall/fix oh hold on a second...not Australia
    Good work VGA don't worry if word of mouth won't damage your brand social media will...slowly but surely.
  5. #85
    Jan 2009
    Quote Originally Posted by GippsCC View Post
    Some references to conspiracy, etc, seem very far fetched - I doubt any manufacturer as large as VAG would deliberately kill future sales (and we are talking massive markets here) by doing anything other than ensuring their cars are safe to drive! No short-cut saving could rationally justify the market at stake, far better a recall than face annihilation.
    It's not a conspiracy - it's just business.
    Volkswagen passenger vehicles sold in 2012:
    Australia = 42,785 units
    Worldwide = 5,738,449 units
    That's less than 1% of total units (or 0.75% to be precise), so with figures like that, they can afford to play the waiting game. It probably wouldn't even matter to Volkswagen HQ if our market were to collapse tomorrow, so I can see them fighting to the bitter end before announcing a recall on all 7-speed DSG transmissions.
    Quote Originally Posted by alexaescht View Post
    Given their statements so far, it would be extraordinary if a recall were to be announced.
    But even if such a recall were to be announced, the engine stalling issue still wouldn't be resolved for vehicles equipped with a manual transmission (as was allegedly the case with Ms Ryan's Golf, and many others).
    Quote Originally Posted by nomadx38 View Post
    It's a given that modern cars are a complex machine, but every major vehicle manufacturer is in the same boat.
    The question is, why is it so difficult for one of the most preeminent vehicle manufacturers to design a reliable failsafe mechanism or program?
    Quote Originally Posted by Hail22 View Post
    It's a calculated risk (EDIT: sorry, not gamble, that would just be naive) that VW have taken, and I'm sure the actuaries have it all worked out.
    Whether it pays off or blows up in their face... remains to be seen.
  6. #86
    AutoBahn
    What I found interesting is what VW singapore said:
    what is the technical issue behind VW DSG recalls?
    Sulphur in the gear oil and an inorganic heat stabiliser in the plastic parts (iodine) of the mechatronic unit can cause metallic surfaces to be attacked and to suffer from electrolytic corrosion, in connection with high air humidity and high outside temperatures. Conducting particles can then settle between the circuit paths of the control unit and could cause a short circuit.
    Correct me if I'm wrong...most of Australia has mild to high levels of humidity...and errrrmmm high external temperatures in the summer...what the deuce?
  7. #87
    Nov 2012
    Morwell, VIC
    RoknRob you missed my point, yes the DSG is a complex box of tricks, but the problem cannot be random. Whether errant code or mechanical failure (and the suggestion is errant code, from what has been said), such a state should be able to be replicated or at the very least recorded - yes, there might be multiple factors involved, but the Volkswagen is full of monitoring units constantly checking the operating state of the vehicle and logging faults - not to mention anyone can plug into VCDS and do their own sophisticated logging of vehicle behaviour realtime should they choose.
    I don't believe in ghosts in the machine - either something exists or it does not, and if it exists it can be recorded and logged. More than a few people have said that this "sudden loss of power" has happened to them repeatedly, so surely someone somewhere can back up these claims with real evidence. I don't say this to discredit anything said, but if no-one can do better than "This happened to me" then this matter seems to lack supportive substance - certainly I doubt anyone anywhere will do anything on such a basis.
    Machines and their software, unlike philosophy or religion, are hard science quantifiable measurable and recordable objects - they do not act randomly (unlike humans) as they are bound by their design and coding, given the same set of circumstances they repeat the same actions (even when those actions are not the ones the designers/coders intended!). That is my point, and right now there seems to be nothing but conjecture, a shakey basis for claiming "death trap".
    I don't work for VW, nor do I have an investment in the issue (beyond owning a VW myself and having driven a VW since 2006). I read The Age story, and what's been said here by some - particularly the claims that somehow VW, the ACCC or the Government are somehow failing the driving public - and I'm befuddled how some of these things can be said on the scant lack of any real evidence. Some are drawing a very, very long bow indeed. As to the problem existing, it's possible, but possible is probably all it will remain until something more is offered up.
    2013 CC 130TDI Night Blue Metallic with Driver Assistance Package, Park Assist 2, Walnut Trim and Ambient Lighting, Front Active Climate Control Seats, Towbar, and Dynaudio Premium Audio.
    My previous ride - 2005 Golf Comfortline DSG 2.0 TDI
  8. #88
    Nov 2012
    Morwell, VIC
    Quote Originally Posted by Diesel_vert View Post
    That was my point, it was highly unlikely to be conspiracy - I didn't claim it to be, just highlighting the silliness of making such claims without evidence.
    I'd also note that the claims being made extend beyond just the 7sp DSG - the car at the centre of The Age article was a manual!
    If a problem exists, VW Australia will be - at some point - confronted with irrefutable proof which means that they would have to conduct a recall at some point. So what do they gain, exactly, by delaying expected damage to their market? (even if Australia is only 1% to them, you are still talking a substantial amount of money - and that's not taking into account negative impacts overseas because media doesn't stop at a country's borders)
    In any case, if I thought VW was selling death traps I'd get rid of my VW and never buy another, but I don't think I'll be doing that anytime soon - certainly not on the basis present.
  9. #89
    Jan 2009
    Unless the seller (VW) has instructions informing the consumer on how to carry out their own diagnostic procedures and be able to interpret the data (not to mention if or how they'll provide such equipment), it would be considered unreasonable (nor expected) that most consumers would (or should) know how to do that.
    You should also keep in mind that it is entirely possible that not all unexpected occurrences or failures are detected or logged by the computer. These systems may be sophisticated, but they are not foolproof.
    Despite all of that, I find it worrying that VW seem to have great difficulty in coming up with a solution for the consumer.
    That is unless, everyone is a troll and is just making these stories up (which is possible, haha!). But in the face of the sheer number of complaints, dismissing it as mere conjecture doesn't seem to be reasonable at this stage.
    With all the media attention VW are receiving, now may be good time for those affected by this to get these issues investigated.
    I know - that's what makes it more concerning.
    If the cause was related to the DSG itself, this may have been the last straw and may well have triggered a recall. Crisis over.
    But on the face of it, this issue of engine stalling doesn't appear to discriminate between gearboxes, which is more troubling.
    I hope all those involved find a solution soon, for everyone's sake.
    It's not a matter of gain, it's a matter of losing the least amount possible.
    They would save lotsa money by not issuing a voluntary recall - unless the cost of lost sales (word of mouth, social media, etc) exceeds the cost of the recall - upon which they would then issue a recall.
    Or unless the regulator demands they issue a recall - but until then, there's no (financial) point of issuing a voluntary recall right now.
    EDIT: depending on the likelihood that a consumer would consult a lawyer.
    If I were in your shoes, neither would I - since the CC doesn't appear to be affected by this.
  10. #90
    Nov 2009
    Hills District, Sydney, NSW
    Re: DSG woes in The Age
