Page 51 of 85 FirstFirst ... 41495051525361 ... LastLast
Results 501 to 510 of 842
Thread: DSG woes in The Age
  1. #501
    Quote Originally Posted by Rawcpoppa View Post
    I think you're right about heat and shift patterns being the main issues for a dey clutch dsg. The juddering I have felt only occurs when the car is in gear 2 and attempting to pull off from low speeds (that I would think gear 1 should be used for) usually under strain like moving uphill or a few occupants in the vehicle. This is only in D mode where the dsg shifts to gear 2 quickly from gear 1 at about 1400-1500 rpm. It feels like trying to accelerate in a manual car in too high a gear (the juddering effect) and I suspect that is exactly what's happening. This doesn't happen in manual mode nor sport as the dq200 won't let you shift out of gear 1 before 1800-2000rpm.
    With respect other it should be noted that the juddering I have experienced usually happens after being in city driving i.e stop start driving and lower speeds. The dsg is heating up basically.
    The higher the temperature the more the friction coefficient of the clutch changes (luk the maker of the dq200 has stated this) and it is more likely to judder as the clutches slip under strain depending on the gearing.
    All of this is from observation, Internet links, te service manager at the VW dealer here and the following is from my user manual for a 2012 Jetta:
    The DQ200 needs air flowing past it to cool down. I don't know what sort of traffic you guys encounter in Australia but think about someone who encounters long stop start traffic where they are crawling a lot. DQ200 temps will rise. It may not be passing the threshold for alarm set by vw but it can still be high. Day in day out this can lead to issues I would think seeing that vw saw it fit to put that notice in their manuals. You guys should point this out to the officials when you make your complaints as I think it points to a fundamental design flaw.
    Well it seems that VW engineers are well aware of the heating problems of the gearbox given that it's a documented issue written into the user manual.
    Now all they need to do is work out how to fix it so they can issue a recall and implement a permanent fix for all the effected cars.
    Trinidad and Tobago
    I doubt there is an easy fix. If there was they would have done it already. As much as people like to rag on VW, if one looks at their TPI's you see they generally issue fixes for known issues with ALOT less furore than seen with this dsg.
    What VW has done is modify the DQ200 in some way. The golf 7, a3, jetta hybrid ALL get new letter designations for the DQ200 dsg. OAM for the first batch from 2008 till present for the vehicles sold as mk5, mk6. Golf 7 and new A3 get OCW and the Jetta hybrid I forgot.
  3. #503
    Jun 2011
    Sydney NSW
    Well, if it is cooling the oil, it is a simple matter of adding an oil cooler attached to the radiator.
    The other thing from this is that you DO NOT CRAWL.
  4. #504
    Aug 2009
    Melbourne, Vic
    Taller gearing does require more clutch slipping to get the car moving smoothly. Just try taking off in second gear all the time - which is what the DSG box effectively does due to short-shifting first gear. Plus in slow moving traffic the fact that first gear does not re-engage until the vehicle comes to a complete standstill means that the DSG will slip the clutch otherwise you'd stall the engine....
    If VW modified the shift pattern of their DSG gearboxes, half their problems would go away overnight.
    The two points I was making to correct two assertions were..
    1) the taller gearing out side of the start off regime that is implemented for fuel economy has little if any effect on clutch slip or wear. I expect changing this part of the shift program will have no effect on DSG issues.
    2) the DSG7 mechatronic unit does not contain hot gearbox oil.
    BTW VW have reflashed and modified the shift patterns in my 118TSI several times since I bought it. Maybe that is why I have had no issues.
  5. #505
    Nov 2007
    Quote Originally Posted by logger View Post
    The DSGs have issues, however in regard to
    Both wrong ....
    1. The 7 Speed gearbox mechatronic unit, which is the most effected of the two main DSGs, contains no gearbox oil. 6 speed does though.
    2. That's pure speculation. I could also speculate that adding a second clutch would double the combined clutch life, when clearly it does not. The cars characteristic of running taller gears is by design and does not mean it has a tendency to "ride" the clutch. I have seen no clear evidence off the taller gear regime being the cause of the DSG7 clutch failures.
    Well mate, as I said, it was "Explained to me", and by no less than 3 VW mechanics .... 2 independent specialists and 1 from VW itself. As a summary these are the main issues and may apply more in some circumstances to a particular model of DSG box but still relevant.
    So, unless you are a qualified VW tech that has evidence and/or experience to the contrary, I'd say my assertions still apply.
  6. #506
    Sep 2009
    Melbourne, VIC
    I don't agree that the media is to blame. The root causes came from VWA for sitting on its hands for far too long, hoping these issues would fade away and be a bygone memory.
    Like a few of members here note it, I've been getting the usual phrases from dealers and VWA.
    - No error was found thru diagnostic
    - What happened in US is not relevant to Aus as specifications, configurations differ (eg PRNDS flashing which happened twice within first 3 months)
    - VWA stands by its quality products but words mean nothing to us as owners when overseas markets extend the DSG/Mechatronic warranty to 10 years.
    - Accelerator pedal kit replacement and throttle-related re-wiring were done on separate occasions. Limp mode and plenty of CEL over 24 months before these were replaced, resulting in lost of confidernce in VW.
    - Other faulty parts like lock mechanism, door handle not properly bolted, high pressure valves, cracked dump pipe. Will all these recur and resulting more downtime?
    I have also written to DIT to highlight those issues. I may not have experience the false neutral while cruising but I wouldn't want it to happen to me or anyone while on the road. I also do not want to bear the costs of future replacements of DSG and Mechatronic if there are inherent faults.
    And having 12 years of driving a manual, I know how to drive one but this edition only comes in DSG. I love the car, don't get me wrong. Just that the attitude and characters of certain groups of individuals running VWA group pisses a lot of us off on one too many occasion.
  7. #507
    Aug 2009
    Melbourne, Vic
    I am not a qualified VW tech so my contradictory evidence must be incorrect. So assert away. But if you feel like being enlightened, have a read of the VWs Service Training Self Study Program "The 7-speed Double-Clutch Transmission 0AM" (You can Google it). While your at it grab a copy for your techs who seemingly have not heave read it either.
    Quote Originally Posted by whoalse
    I tend to agree with you an this Whoalse. Will be very interesting to see what transpires next week.
  8. #508
    Jun 2013
    I've just been going through DSG woes at the same time as all the media goings-on, which has been interesting (never had any deceleration etc., but just the massive shudders). Had my auto 2009 Golf 118TSI (30,000km and out of warranty) towed a week ago. VW fixed the clutch pack for free under the new five year warranty and I really pushed for the mechatronics unit to be replaced as well, but they said no. Car got towed again on Friday, as had another massive shudder. Can anyone tell me what I should be pushing for them to do? Anything other than the mechatronics unit? Do you think they'll be doing anything else if the recall goes ahead? Any info would be a real help as this isn't exactly my area of expertise (am a journo, so have been having a Twitter/Facebook field day, though...).
  9. #509
    Feb 2013
    VIC
    DSG woes in The Age
    Quote Originally Posted by whoalse View Post
    I agree, even if a recall was made and a so call fix is provided both future DSG return fault expenses and resale value will be on us the loyal customers.
    Additional 10 year transferable warranty for the DSG/mechatronic is required to assist in the resale and restore confidence.
    I took my skoda 118with 7 DSG gearbox and all they did was delete all old error, did a test drive while resetting DSG configuration and check if the firmware is updated.
    At the end I got a printout of an error free car. This does not restore my confidence as I knew I had no issues with my car at current time.
    Saying this they did tell me no additional information or recall has been provided by VW at current time.
    I guess all we can do is wait and see VW response next week.
  10. #510
    Erskineville, NSW
    I said that the resale values don't come to their mind. It's good to see that we both agree
    Heaven forbid!
