Page 25 of 85 FirstFirst ... 1523242526273575 ... LastLast
Results 241 to 250 of 842
Thread: DSG woes in The Age
  1. #241
    Quote Originally Posted by muli View Post
    Yes that was in Sweden and was the Passat.
    EDIT: http://www.teknikensvarld.se/2012/12...****-som-taxi/ its in Swedish tho but seems it only affected Passats running on gas
    yes, VW recommends the Touran TSI EcoFuel with...the 7DSG gearbox
  2. #242
    Doesn't Sound Good.
  3. #243
    AutoBahn
    I believe the safest and best option for both sides (VWA and consumers) is that VW announce an extended driveline warranty (engine, box, clutch, DSG) for 10 years exactly like China...that at least would remove the need for a recall but adds stability and confidence back into the brand / second hand VW's.
  4. #244
    Quote Originally Posted by OzVWCrap View Post
    You seem to have some technical knowledge, so here is my vehicle's info below. Are you saying this model does NOT have the DSG problems, or only that it is not covered by the recall in other countries?
    That's a TDI? If so, then if it has a dsg gearbox its the wet clutch 6 speed unit. The one that is causing all the grief and the recalls is the dry clutch 7 speed unit most commonly found here in 1.2 and 1.4L petrol VW etc.
  5. #245
    May 2013
    Qld
    Quote Originally Posted by pologti18t View Post
    So instead of a 7 speed Passat they say use a 7 speed Touran? is there more than one model of the 7speed DSG?
  6. #246
    Jan 2009
    Quote Originally Posted by gavs View Post
    What needs to happen is that VGA should be made to repay owners a percentage of the drop in resale value of the car, I say $6000 per car with this gearbox for polos, $9k for golfs, $12 for passats etc. On top of that, be forced to publically admit in writing that there is an issue, then those warranty claims that dealers have refused because they "can't find any problem" can be contested, resulting in full gearbox replacement including clutch packs and mechatronics units.
    Finally, a $15,000,000 fine for misleading the public and putting all owners of vehicles with the dq200 in (greater than usual on the roads) harms way.
    An overly ambitious lawyer with German connections in high places might consider going after Volkswagen AG itself, who last year made an after tax profit of EUR 22 billion, so even 0.01% of that roughly equates to an amount of EUR 222 million (AUD 300 million).
    There's a retirement plan right there, albeit a little risky.
    Quote Originally Posted by pepperpolo View Post
    Anyone know what a new metritronics unit costs, installed (estimate)?
    Anyone know what a new clutch pack costs, installed (estimate)?
    I'm not 100% sure, but here are my estimates if purchased from an Australian VW dealer (parts only, excluding fitting):
    The mechatronics unit would probably cost about $4,500.
    The clutch pack would probably cost about $2,000.
    It is concerning. Mine is about to tick over 3 years old and I haven't really had any problems (touch wood) although I have been paying more attention and now i think my mind plays tricks on me.
    As Hail said, the transmission warranty is now 5 years or 150 000 km (whichever you reach first) from the vehicle's delivery date, but best to confirm with VW.
    Link: General Warranty Terms and Conditions - Volkswagen Australia
    That my friend, is a 103 TDI common-rail engine with a DPF (CBAB) attached to a DQ250 6-speed DSG transmission (LQV).
    Although the DQ250 6-speed DSG transmission isn't trouble-free (earlier units often needed a replacement mechatronics unit under warranty, which costs about $4,000), it is not the DSG transmission in question that is currently subject to a recall in several countries - that would be the DQ200 7-speed DSG transmission.
  7. #247
    May 2013
    Qld
    Re: DSG woes in The Age
    The 5yr/150k driveline warranty apply to skoda/audi etc as well?
  8. #248
    DSG woes in The Age
    No idea what the Sharan uses, but there is a 7 speed wet clutch DSG, used in the TDI Tiguan.
    Alex Aescht
    MY13 Dark Silver VW up! 5-door 55MPI manual — Comfort Style Pack, Comfort Drive Pack, Maps + More, Panoramic Sunroof
    MY11 Pepper Grey VW Polo Comfortline 66TDI manual ― Comfort Pack, Audio Pack.
  9. #249
    Jan 2009
    Thanks. I've now done 4 years and 25000km in the car ... would a dud mechatronics unit have shown up by now?
    The fact that you have a Mk6 Golf (5K1) lessens the likelihood of there being a dud mechatronics unit, but unless one has a crystal ball, one can never say for certain.
    If your car is still acting up, and if the fault lies with the mech unit, and if your car is less than 5 years old from its delivery date, you might still be in with a chance of getting it replaced under warranty:
    That is, assuming that your car is covered by the 5 year / 150 000 km transmission warranty. Best to confirm with VW.
    Having said that, I'd waste no time in selling it as soon as it's practicable if it's causing you such angst, or you feel that it will cause you such angst in the near future - you don't need this in your life.
    From what I can tell, that doesn't appear to be the case.
  10. #250
    Sep 2009
    Hobart, TAS
    Free extended warranty only applies to 2013+ model cars. Doesn't really help me out with a MY11 that's still under warranty
