7-speed, I assume?
No filter on them, and did you drain the gearbox (rear plug), or the Mechatronics (front plug)?
These aren't a serviceable box (at this stage), so getting hold of the tools to sort it out will be tricky.
This might help: http://www-odi.nhtsa.dot.gov/acms/cs...3V568-9034.pdf
Additional info may be found in here: VWVortex.com - DQ200 DSG in global recall. Possibly affects Jetta Hybrid.
