Originally Posted by
wagonist
This is what I'm doing, but wondering what's actually happening with the gearset inside the transmission.
ie is there a synchromesh system a bit like a manual, or is neutral a setting where both clutches are disengaged, or something else?
Your question has been answered by both Lucas and I and if you have AUTOHOLD on it shouldnt move until you dab the loud pedal
The DSG is a manual gearbox with electronically controlled clutches. It works by putting the gearbox into first on no 1 clutch and 2nd on no 2 clutch as you speed up it swaps clutches and the other one goes to 3rd and waits and so on up to 7th.
As you decelerate the opposite happens but normally it only goes back to 2nd unless you actually stop.
Should you go back to (say) 3rd and suddenly hit the loud pedal it will say to its self Oh **** i thought you were slowing and has to swap from 2nd to 4th so thats why you get that momentary pause as it cant read your mind
There endeth the lesson
