Results 1 to 8 of 8
Thread: Downpipes??
    May 2009
    Townsville,QLD
    Downpipes??
    Ok, as I'm learning more about VW here than Google I'll ask yet another question..
    Is a Downpipe Illegal and is it worth using?
    2009 125TDI Passat
    2002 B5.5 1.8T Passat
    Jun 2009
    No, a downpipe is not illegal.
    You are thinking of a screamer pipe.
    It is definitely worth using.
    In a lot of cases it is the most restrictive part of the air-flow system and as such, a better flowing downpipe will net you more power.
    Point Cook, Vic
    in some states any modification to your exhaust is not roadworthy unless accompanied by an engineers report. Best thing to do is to confirm with your local transport authority.
    Looks like it may be ok in QLD. there is a basic modification guideline booklet here.
    http://www.transport.qld.gov.au/reso..._vehicles2.pdf
    FOLLOW US ON FACEBOOK
    Jan 2009
    blankedy
    Dump pipe / Down pipe is the first stage of exhaust from the turbo.
    Often it is replaced after a car is chipped to handle increased airflow.
    For 1.8T's with standard turbo, 2.5 is enough for the flow (stock is often 2.25").
    Worthy when accompanied by a chip and some work to the intake section if required.
    May 2009
    Townsville,QLD
    Ok Thanks,
    Is it a n easy remove/replace process?
    You guys are so good at this
    2009 125TDI Passat
    melbourne
    hey brett how's it going?
    im not going to claim as i'm a kook when it comes to cars, but yes- this forum is full of enthusiasts with a good knowledge base.
    with dump pipes, whilst there are many people on here with their dump pipe (from turbo to catalytic converter) replaced, i dont know of anyone who's done the work themselves. im sure that some would have, with their own welding tools/ mechanical skills, but for the most part, people would go to a custom exhaust shop and have them fab one up.
    there is much debate as to how much a dump pipe should cost- some will say easily more than $600, others will say they got away for much less than that, but either way, it's almost a must when you've got your car chipped.
    first thing i would look at doing in your shoes, is a chip.
    there are many companies out there which do the 1.8t- revo technik, apr, giac, custom code, superchips, etc etc . check them out- they're a VERY worthy investment. when you get chipped, it's like you're driving a different car.
    good luck!
    Sep 2008
    Townsville
    Im sure if you poked arround the net you could find a good priced downpipe and Jay or myself could help you install it .
    Did mine without any issues and im sure its a little tighter spot to work in than the ssat.
    Or HiFLow exhaust (local shop) could make you up one from scratch for a good price and they do good work.
    May 2009
    Townsville,QLD
    Quote Originally Posted by kaneda View Post
    Thanks Steve, I'm trying to decide on 17'/18' rims at the moment...then
    I'm keen to chip if you can steer me right direction as to which one to get also. I'll definitely contact you both as too helpin out.
    Brett
    2009 125TDI Passat
