Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Dead battery covered under 3yr warranty
    Mt Cotton
    Thanks feenix74 thats one supporter , I was concerned that I would draw the ire of those who cherish their technology .Ha Ha . But hey as Jack Palance said in City Slickers "day aint over yet "!
    I am with you too Sunny ..... My Focus ST battery is in a location that required me to be able to do a contortionist act whilst being able to lift a 17kg battery with just 2 fingers. Not to mention all the protective covers that is sits under which alone took 15 minutes to remove and required watching an instructional video from youtube ...
    What happened to locating the car battery in an accessible location which takes 5 minutes to pop out and change ?
    RS
    R
    Mt Cotton
    Should try and find a Grand Jeep battery they hide the bastard under the front seat !!
    Quote Originally Posted by agentthumb View Post
    Battery doesn't have a BEM sticker. It's an Enirgi branded one with the same spec. So I'm just going to change the serial number in BCM to trick it into thinking there is a new battery.
    Agentthumb: hmm.......... at least it's an AGM battery (good thing). Yes, just make the serial number something different. All the CAN Gateway admaps the I have in my database have the same serial number - so it's not important to input an actual number.
    Quote Originally Posted by godzilr View Post
    If you buy a battery from the dealer, based on your VIN, do you still need to make any changes through VCDS?
    godzilr: As I said in my response to Agenthumb, these matters are really only important if the car has a battery monitor fitted (see my picture in the other post). The CAN Gateway module can't distinguish if the new battery is based on the VIN, or not (and frankly, it doesn't matter). You have to tell the Gateway that a new battery is fitted (if the battery monitor is hanging-off the negative battery terminal).
