Results 1 to 6 of 6
Thread: Deactivating DRL when indicator on
    Jun 2011
    Sydney NSW
    I've noticed that a number of cars with DRLs now deactivate the DRL on the side an indicator is being used because with some headlight clusters the DRL can hide the fact that an indicator is being used. So far I've seen this on a Range Rover, Benz, BMW, and the most recent one was a Mitsubishi.
    When I first saw this, I thought it was a DRL that had failed, but then saw the indicator operating. As soon as the indicator stopped, the DRL came back on.
    I wonder how long it will be before there is a software update for the VW range to incorporate this.
    I have to say that it does look slightly weird, however the indicator can be seen more easily compared to when the DRL is on all the time.
    I believe Audi were the first ones to do this a few years ago, and more recently the other brands have started to use it. A work collegue has a 2012 Jeep Cherokee and it does it too.
    I agree it does look like the DRL has broken, but does also make it easier to see that the indicator is on for other traffic.
    Jan 2009
    I've seen the MK7 Golf do that.
    May 2013
    Orange NSW
    I have a mk5 and it is in the computer to set. All you need is a VAGCOM cable to set it up.
    08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
    http://photobucket.com/gregsr32
    Jun 2011
    Sydney NSW
    Quote Originally Posted by greg32 View Post
    Interesting.
    I have a MY11 Caddy Maxi Life, so theoretically it should be there (I hope). It goes in for the DSG recall service on the 6th, so I might ask if it can be done.
    Are there any pre-requisites?
    Nov 2009
    You can code the DRL to dim (not completely turn off) on the Mk6 Golf - at least with the xenon cluster (not sure about the halogen type).
