Originally Posted by
Lucas_R
I would be checking myself if the services have been done - i wouldnt trust what the seller is saying.
The water pump was a service item on the older Mk5 engine, but not (as far a sim aware) on the Mk6 GTI engine. Its tucked away right up under the inlet manifold, so not an easy thing to check/access. If it hasnt broken by now id say you are safe.
With the car being a manual, you dont need to stress about the DSG services which are important and expensive. If your gearbox oil hasnt been changed yet then that is something i would be doing sooner rather than later.
Brake fluid/clutch fluid should have been changed multiple times by now. Coolant/radiator fluid should have been changed at least once by now. You might want to check the accessory belts for wear too. Fuel filter should have been replaced twice by now. But the most important thing is that it has hopefully had regular and consistent oil and filter changes with a VW approved oil.
I'll post up a link later for a scan tool.
As for mechanics, Exoticars at Parramatta, VW village at Kensington, BWA auto at Seven Hills.....theres a few around.
