Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Copper sump plug crush washers
    Mar 2009
    I have replaced the standard sump plug in my MkV GTI (I believe most VAGs use the same sump plug) with a Magnetic sump plug.
    Can someone confirm if there are any issues using a copper sump plug crush washer. I think the original looks like steel (washer and bolt is disposed each time).
    Also is the size Aluminum Drain Plug Washer M14x20?
    MY07 Red GTI 3 Door
    Dec 2014
    My car's original sump plug installed in the factory was aluminium with an aluminium washer. The dealers always replace these at every service with a new steel plug with a captive steel washer. I was annoyed they threw mine away as it only needed a new washer and could have been used indefinitely. I never felt comfortable that the steel plug used by VW was made of a harder material than the sump.
    I too installed a magnetic plug (from ECS Tuning) that was supposed to come with 10 copper washers. I determined the 10 washers I received are actually brass - too hard in my opinion. So I bought a number of aluminium washers - sorry don't know the size.
    My own opinion on washers is:
    aluminium - best
    copper - OK
    brass - no
    steel - no way
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
    Dec 2008
    Sydney/Canberra
    They're 14mm ID.
    You can pick up bulk lots of them on Ebay for stuff-all.
    Mar 2009
    Yeah going to order from eBay, just wanted to confirm the size (14mm).
    Quote Originally Posted by 3C4M Guy View Post
    aluminium - best
    copper - OK
    brass - no
    steel - no way
    I'm not sure why they use a steel plug and washer, and then replace both of them. I'd too be upset they if replaced an aluminium plug with a steel one.
    You can pick up what looks to be a aluminium plug with magnetic tip for a few dollars on ebay.
    I too have the ECS plug. I lost the 10 washers so am looking for replacements. You may be correct, they did look hard so was replaced by an aluminum washer.
    I think the plug was over tightened so I can't even get the washer off the plug! Thank god the sump plug hole wasn't damaged.
    Sent from my SM-G930F using Tapatalk
    MY07 Red GTI 3 Door
    Dec 2008
    Sydney/Canberra
    The washer on the OEM plug is captive.
    Over several uses, the washer becomes thinner, the plug distorts, and eventually trashes the thread in the sump.
    As cheap $4.50 insurance, dealership practice, is to replace the whole thing each time. Much cheaper than replacing or repairing a sump.
    Sep 2015
    Be careful mixing and matching metal alloys, some combinations can cause electrolytic reactions. Just ask the owner of an aluminium dinghy what happens if a fishing tackle swivel remains undetected on the floor...
    I had a magnetic sump plug and washers from ECS Tuning, but found that i always had oil leaking out. Swapped back to the OEM sump plug and no more leaks.
    Apr 2006
    VW Race HQ - Sydney
    Thats because at some stage the plug was overtightened ! Once its overtightened once they start to leak , the more overtightened the worse the leak is . My own Golf R which has 90k kms and oil changed every 5k kms is bone dry .
    Bug_racer supports the rebellion of the euro revolution
    Quote Originally Posted by Bug_racer View Post
    Ahh fair point. I had one on my old Golf R and never had an issue, but it leaked on my GTI....i have now reverted back to OEM plug and its all good again. Never crossed my mind that it may have been damaged from over-tightening.
    Dec 2008
    Sydney/Canberra
    On the GTI with the tin sump, there's a specific plug and separate washer for them. Those, you can just replace the washer on it's own.
    If you use the regular plug with the captive washer on them, it'll leak.
