Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Copper sump plug crush washers
  1. #21
    Aug 2016
    NSW
    I kept forgetting to buy a new plug for about half a dozen oil changes...........and now it won't come out! (spins around)
    Not leaking (yet) but has anyone had any experience in this situation?
    2018 Crafter Runner
    2012 T5.1 6sp manual.
    2024 Crafter Auto
  2. #22
    Adelaide hills, SA
    Quote Originally Posted by LogicprObe View Post
    Most likely what happened is that every time you remove sump plug you over tightened it, more and more until the thread stripped.
    You probably need to buy an oversized sump plug kit (eBay is your friend).
    When reinstalling sump plug, use normal length spanner and think about it as it was just M8 bolt not M14.
    It’s not unusual that I often need to reach for 600mm breaker bar and use a lot of force to undo some sump plugs, even the oil filters.
  3. #23
    Adelaide hills, SA
    While turning the sump plug try to wedge the screw driver under the socket and apply the pressure like you would want to pry it out of the sump, hopefully it will come out.
  4. #24
    Aug 2016
    NSW
    Thanks.
    That was what I was going to try at the next oil change.
    Just want to be prepared!
    2018 Crafter Runner
    2024 Crafter Auto
  5. #25
    Mt Cotton
    I think you can buy a thing called a helicoil insert to fix stripped threads.HeliCoil
  6. #26
    Adelaide hills, SA
    They're good for the blind holes, not so good repairing thread in the sump.
