Results 11 to 20 of 26
Thread: Copper sump plug crush washers
    And now, we have the plastic sump with a plastic plug (rubber washer).
    MK6 MY10 Golf GTI, 5dr Manual, Carbon Steel, Detroits, Tint
    T6 MY06 Peugeot 307 HDi Touring, Manual, Iron Grey, Tint
    Mar 2009
    Quote Originally Posted by Mi16 Man View Post
    A solution to a non existent problem. Good thing plastic sumps are more durable :O
    Although I see the benefits of a metal sump with plastic plug.
    My old car had a rubber washer (metal plug), IMO better than crush washer.
    Sent from my SM-G930F using Tapatalk
    MY07 Red GTI 3 Door
    Dec 2014
    I happened to have my washers out, so I thought I'd check the sizing on a selection of various different ones.
    They all seem to have an ID of 14.4mm and an OD of 19.9mm. That should a guide for you Johnbu when buying more.
    Recently I bought some aluminium ones from a Euro service specialist in Richmond (Melbourne).
    2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
    Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
    Mar 2009
    Quote Originally Posted by 3C4M Guy View Post
    Thanks, good to know.
    Which place was it and how much did they charge you? I may pick it up rather than ordering them online if not too expensive.
    MY07 Red GTI 3 Door
    Dec 2014
    PM sent
    Mar 2016
    Townsville Qld
    As a newbie to VW, (2010 Golf 118TSI)
    Which one too buy or other options,
    http://www.ebay.com.au/itm/181950993186?rmvSB=true
    https://runautoparts.com.au/audi-a1-...n90813202.html
    https://www.europaparts.com/magnetic...metalnerd.html
    Also, Is it better to buy OEM Oil Filter or Ryco (Z794 I think)
    Dec 2008
    Sydney/Canberra
    OEM over Ryco any day of the week.
    Will most likely be cheaper too.
    Nov 2015
    Run Auto Parts also sell Mann oil filters at a competitive price. Mann is one of the suppliers who manufacture the OEM oil filter for VW Group.
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
    Mar 2009
    I had a magnetic sump plug and washers from ECS Tuning, but found that i always had oil leaking out. Swapped back to the OEM sump plug and no more leaks.
    Quote Originally Posted by Bug_racer View Post
    Thats because at some stage the plug was overtightened ! Once its overtightened once they start to leak , the more overtightened the worse the leak is . My own Golf R which has 90k kms and oil changed every 5k kms is bone dry .
    I've now gone back to OEM sump plug.
    Used the ECS sump plug for a couple of years, changed the oil last week and used a new washer ECS provided (found them) and leaks overnight.
    After hand tightening the plug I could tighten with a rachet without much torque but even after 1/2 a turn it never felt very tight, almost like it was stripping the pan. Not a good feeling.
    Switched to the OEM plug today and after hand tightening it, it was very tight after a 1/6th of a turn. Felt much more reassuring.
    Anyway will only use a new OEM plug for every oil change from now.
    Maybe the ECS plug was overtightened once before, maybe it wasn't. It's in the bin now. I had an iffy feeling about it from day one due to the brass washer (definately not copper).
    MY07 Red GTI 3 Door
    May 2006
    Adelaide South Australia
    For years now, I use a torque wrench for the sump plug & the plastic cover [on mime] on top of the oil filter. My sump plug doesn't leak & the oil filter cover is not too tight to remove. I wouldn't bother fitting a magnetic drain plug.
    Numerous Mk1 Golf diesels
