Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: BBS RS wheels and stepping up
    May 2010
    Richmond, VIC
    Looking at buying a set of BBS RS 008's (16x7")
    Is it possible to step these up using lips and make them 18" using the same centers ?
    Or am I just dreaming and should start with 18"
    Fitting them to my s3 8l
    Sep 2006
    Hmmmmm I dont know how you make 16inch wheels into 18 inch wheels lol
    You can turn the 16X7 into a 16X8 or 16X9 etc using wider lips
    MODS- TOO MANY
    Quote Originally Posted by bootheman View Post
    It can be done I believe. But anything can with a big enough cheque book..
    I'd suggest looking for 18" super RS's. If you can't find those some 17" RS's with the correct offset and ride height would look just as horn
    Jun 2007
    Eastern Suburbs Melbourne
    simple answer is no,.
    I've heard of some 17" centres being used with to make 18" wheels, but this is pretty expensive, as you'd need new barrels and lips.
    I think you're better off trying to find some 18" RS's to start off with,
    i like volkswagens
    May 2010
    Richmond, VIC
    Bugger cheap!!!!!!! Set of rs 008's in eBay!
    http://item.mobileweb.ebay.com.au/vi...d=110753323208
    Up for grabs?
    Suffolk UK
    Ask these guys, Jeremy will be able to give you an answer... I thought the 17's used the same centres as 16's (as long as they're 34 bolt) and 17's can be made into 18's, so....
    JustMatz - BBS Information
    Sep 2006
    West Sydney
    The 18" BBS RS do share the same centres as the 17" BBS RS. And I've heard the 16" BBS RS share the same centre as the 17". So does that mean a 16" could be made into an 18"? Sounds about right..
    Give Rotiform an email. I know they refurbed the lips on a set of BBS RS285 (18" BBS RS in BMW fitment, but the owner swapped the centres out for 5x112 centres from 17" BBS RS).
    as above, im sure it could be done for the right $$.
    May 2010
    Richmond, VIC
    I thought so love the rs!
    U seen the new wagenwerks DVD?
    **** hot!!!!
    Nar...
    Im guessing you've seen the A4 with the over sized lips? if so I believe they are the genuine 18" RS
