Results 1 to 10 of 30
Thread: Battery choices
    Adelaide hills, SA
    Just to clarify Transporter , using a standard battery is ok , if the stop start is just left as it is the car will still drive as per normal is that correct or is there a problem related to not disabling it , it can be disabled everytime you drive by just turning it off so to speak .
    Yes, it is.
    Mt Cotton
    Thank you for the replies , I think I have the answer now .
    Ok edit time today I had a look at this battery with my glasses on and discovered it has already been replaced with an AGM Battery 19-1 17 so it seems the original had only lasted shade under two years as its a 2015 model registered in February that year which is pretty poor . Now if this one has gone then its also a shade close to two years also pretty poor form . So tommorrow after the Qld holiday I am going to ring the number on the battery and see whats cooking as I think any battery should last more than two years surely .
