Originally Posted by
Transporter
Oh, AGM batteries last longer, just turn the stop start off.
You could get Century battery from SCA, which if you buy AGM is made in Germany (most likely Varna), for $90 more.
Just got a new Century Battery from SCA for $186. Old one stopped after 8 years, which I figure is reasonable. May have just been flattened by lights staying on, which seems odd since they shouldn't on auto. Battery window looked empty, so the manual says not to try to recharge.
DIN53LH MF is the same size as original, but slightly lower capacity and higher CCA.
Thought Century were made in Oz, but not any more, Korea for this one. Came with vent tube but without any instructions, which is appallingly bad. Web site says DIN Stop Start batteries have vent tube and that leaving the red plug in place is dangerous. But mine isn't a stop start battery and century has no battery instructions I can find so far. Anyway the vent tube is in, but where is it meant to go to??? I have pointed it at a recess in the plastic battery tray, since I don't really want possibly acidic gas/liquid going anywhere else.
So presumably a vent means the "maintenance free" battery can dry out over time in the hot engine bay.
Next time, I might have to fork out for a european made Varta. (Only the dearest are made in Germany.) Varta says E44, or Century DIN75LH MF, but both of those are bigger that OE Varta and it sounds like I need the bigger battery blanket/cover to prevent heat soak.
So, just wondering - what is the value equation cost/lifespan for: bigger vs smaller (OE size); vented vs sealed; blanket vs not.
2015 Polo Comfortline 6M + Driving Comfort Package
2011/11 Yeti 103 TDI 6M + Columbus media centre/satnav
(2008 MY09 Polo 9N3 TDI retired hurt hail damage)
