Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Aroma or Smell
    Erskineville, NSW
    It sounds like you are hyper-sensitive to solvents. Have you worked with similar chemicals a lot in the past?
    Windows down whenever you can - parked, moving , whatever.
    HVAC on fresh air & fan on 25-50% (I can't believe how many people drive on recirc)
    Sprinkle a box of bicarb soda all over the floor mats - vacuum off after a week.
    Park car in sun with windows open. The heat will make the plastic outgas quicker.
    wipe over all the hard surfaces with a water solution that is 10% white vinegar (the cheap crap you buy in 2L bottles).
    as above but use vanilla essence (a capful in a litre of water).
    Jun 2008
    Emerald, Vic
    Correct me if I am wrong, but aren't most new car smells coming from things like the new plastic releasing agents impregnated during manufacture / byproduct of the 'ingredients' that go into plastic along with the glue/stickyiness in the wiring loom and such like? in which case a lot of the sprays and what not are not going to reach a lot of the surfaces generating the smell?
    My Car(s): 2011 6R TSI Comfortline (Pepper Silver),
    If you're in need of any 6n1 parts, odds are that I am going to have them (dismantling 2 at the moment)
    Erskineville, NSW
    You are right.
    Ialso recomend a spirited drive somewhere (preferably up a mountain) to burn off the greasy coating on the engine, exhaust, etc.
