Ordered!!
noone - black stealth catch can, shift bushings, quick drain kit, PCV T fitting, 2 x 90 deg PCV fitting confirmed
kangfu - shifter bushings MKV 5s MY06-07 confirmed
vwthunder - black stealth can confirmed
thestu - black stealth catch can, quick drain kit, MK3 triple gauge dash holder, black stainless Y piece confirmed.
mrbrossnan - MKV street - res / cat ceramic downpipe and an O2 spacer confirmed $100 deposit
isaw - MKV street - res / cat ceramic downpipe after x-mas confirmed $100 deposit
ryana89 - VDO international 12v and 80psi oil pressure gauge, pressure sender 80psi confirmed
gjuu - black stealth can, quick drain kit, polo GTI bushings confirmed
gldgti - EGT, 80psi oil, 30 psi boost international VDO gauges, 80psi NPT oil pressure sender and a MK3 triple panel confirmed
BDShenanigans MK IV shift bushings, MKIV 10pc Red LED kit, 2 x 194 white hi LED's, 2 x Licence plate LED confirmed.
Lucas Steath catch can solution and quick drain kit black confirmed
