Results 1 to 9 of 9
Thread: 020 gear shifter options
    Sep 2006
    Didn't know where to put this...
    But I hate my sloppy shifter.
    Looking at the USRT shifter but it's ~US$150. Then there's $10-$50 bush only kits.
    What's everyone else got?
    Nov 2005
    ive got custom spun brass bushes where the linkages are, rather than the plastic ones, as precise shifting as you can get!
    dom
    Sep 2006
    West Sydney
    I'm using the bush replacement kits (changed out everything from the subframe forward) and it helped the side-to-side greatly. Back-and-forth play is still present, and I think I'll need to change out the shifter ball/bushings directly below the shift knob (gotta move the cat to gain access I think). I've got the Autotech short shifter too and it helps with the illusion that it tightens everything up too. I've got it at the shortest throw and it's perfect for me. Notchy without being difficult to get into gear.
    The bush kit I bought was very cheap (from a UK site, don't remember the name...) and it's been on the car for approximately half a year now. One of the plastic ball-socket linkages (the short white one) broke on me just after a month of use and I was stuck with 3rd and 4th gear for a while hahaha. I may have received a crappy one as I've got my old one back in and it's serving me well.
    USRT for the price, I suspect, is great if you're doing any racing. Otherwise the OEM replacements are good for another few years of service. Just remember to change out the shifter ball/bushings to eliminate all play.
    Sep 2006
    OK what do you think then? (these are from GAP)
    Shifter rebuild kit. Includes shift lever pivot assembly, shift linkage bushings, selector rods, relay shaft, and neoprene washers.
    Includes all common wear items, see photo. $49.80
    and what about this... do I need this one as well?
    Relay lever repair kit. Includes relay lever, bolt and nut, two bushings and two neoprene washers. Pivots on bracket on transmission, the selector rods attach to this lever. $9.50
    Jun 2008
    Tassie
    Have a look here:
    MissingLinkZ - VW Shift Linkage Upgrades
    The Missing Link - does linkages for Mk1&2 and other VAG vehicles.
    Chris
    Sep 2006
    Australia?
    Have a look at gruvenparts, some billet style sexiness is what you need
    Aug 2007
    Five Dock, Sydney
    what about deisel geek short shifter? happy to split a ship on a couple, if they make them to suit your mk3
    '03 Bora V6 4motion ~ CC Flash ~ Neuspeed F&R ARB ~ .:R optioned - Bilsteins,Springs,shifter,steering ~ Tyrol Brake kit ~ EVOMS CAI
    Sep 2006
    Dieselgeek only do shifter linkages for the newer ones. I want to get a kit with all the bushes etc
    sydney
    im in for a diesel geeks for an 02a??group buy??
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
