ha ha no mate apparently they coat them twice, 12 dollars per coat and 2 coats per wheel.....~$100
ey carl a word of warning before you powdercoat them.......... make sure you sand the surfaces of those wheels, because they will stay rough once powdercoated, when i blasted my 17's i had to sand all those spokes!! i wanted to die!!
dom
mk2 GTi 16v
Corrado G60
that is very very cheap
bit of an update on this one people, have been quietly and slowly been working on these wheels.
Chose to go for a slightly different look so I have modified them a little to suit the cars large flat surfaces.
The wheels after sand blasting....
then....
and....
At this stage they still need some more sanding and spraying to get the surface perfect. But am not in a rush.
mk2 GTi 16v
Corrado G60
did you spray them?
I thought you were getting powder coat?
good work, they look great filled in. will look sweet on a mk 2.
I must say they look a ton better with that indent filled in!! Pics of them on the car when you're done!
Got pics of it on the car?
I rekon 17s look a bit silly.![]()
MK1 GLS 3door
A4 B7 2.0T
