![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
wai
Tyres have a code moulded into the sidewall with the year past which they should not be used. It is not the km so much, but the age that can make the tyres fail.
I had a Goodyear Supersteel rip open in the boot of my car. It was the spare, but it failed along the length of a groove in the tread. The images are posted on the forum.
Supersteels were junk so it's no surprise. 10% of the tyres I "sold" when I was at Goodyear were warranty replacements for Supersteels.
While I'm aware of production dates on tyre. I don't recall there being a "use by date". Happy to be wrong.
To the OP: As long as you haven't any cracks / perish marks then they should be OK. Keep in mind the rubber will have age hardened a bit so they will wear at a lesser rate now than when new & also have slightly less "grip". Combine this with the reduced tread depth (which if you have 20,000km estimated remaining is only 1mm before the wear bars) and the wet traction/grip might be marginal.
IIRC, in germany/austria they make you throw the tyres away when they are 7 years after the build date (or maybe I misunderstood my wife's cousins - my German is pretty lousy)
