Google wheel offset calculator (the +35/38 goes with the wheel width btw) and the tyre size calculator and use that to help you see the suitability.
Both are on 1010tyres.com
HTH
Does anyone know if these tyres will fit the polo Gti?
16"x8'
Fronts +35 offset- 205/55/16 Goodyear Super Ducaro F1 70%
Rears +38 offset- 225/55/16 Bridgestone G Grid 55%
***If NOT could you please tell me the specs of the tyres our cars can fit, in terms of the profile and
offsets. someone enlighten with my lack of information on these cars =D thx!
HTH
Since I'm after a similar answer:
Stock Specs
Width: 6.5 inches/ 45mm offset
New Wheel Specs
Width: 8 inches/ 35mm offset
Inner Clearance: 9mm LESS (the inside of the wheel to the struth housing)
Outer position: EXTEND an extra 29mm (position of the outside edge of the wheel)
Wheel Offset Calculator
Just a little off topic:
Does anyone know how I would be able to tell if the tyres would rub against the guard? As mentioned previously, I'm looking at Bilstein B8's with 35mm H&R springs, but with a 215/45/17 setup. I have 17x8" rims. It may be that I need to opt for a different spring height, perhaps a 20mm/15mm drop to clear the drop, since 215/45 is just over 2cm taller than 215/40.
Height wise, I know I'll be fine because I can opt for a different spring rate drop (i.e 15, 20, 35mm). But - would a 215/45 setup be a problem when turning? (i.e rubbing inner guard)
Can anyone shed some light!!?
If you use your wheels as a guide, getting the tyres to sit square shouldered on the rim, your rim clears (as long as there isn't a massive angleo n your struts) your tyres should hopefully be fun.
Go "undersize" tyres (stretch) and you are guranteed to be fine. Balloon tyres (like a 45 or 50 or 55 profile) and you are just as guranteed to have problems.
Compared to 205/45/16 (on the same rim width)
- 205/55/16 - will have 41mm more in overall diameter -> the car will be raised with ~20mm
- 225/55/16 - will have 63mm more in overall diameter -> the car will be raised with ~30mm
stretching them on rims with 8 inches width - will give less diference in diameter... but there will still be some difference
55 profile seems too large, think you will change the rolling diamter which influences the gearing and speedo.
does anyone knows if a 225/45/17 tyre will fit underneath a lowered polo?
if not, can i resolve this issue when i Put 215/40/17 on the rims so the tyres are a bit stretched?
225/45/17 (compared to 205/45/16) - has 43mm more in diameter - so the car will be raised with ~21.5mm... and the distance between the upper part of the tire and the wheel arch will be reduced by ~21.5mm...
215/40/17 would be more suitable, as the difference in diameter is only 13mm.
USE THE CALCULATORS people.
215 / 40 / 17 (width of tyres, same regardless of size / 40% of 215mm profile = height / 17 inch)
Polos will only take:
1) 205/45/16 or 215/45/16
2) 205/40/17 or 215/40/17
If you go 225, you are likely to run into problems with rubbing at full lock.
The width of the alloy wheels - should be only between 6.5" to 7.5" at max. 8" means the tyres will be stretched. I wouldn't recommend it. 205/45/17 on 7.5 inch is already small stretch which I do not like. - easier to curb wheels etc.
I am talking about recommended and safe sizes only. You can put whatever you like. :p
06 Polo GTI - REVO Stage 2 = 140kw @ wheels.
06 Golf GTI - Bluefin Stage 1 blacked out with ED30 theme, leather, xenon, etc.
