Well as a comparison for inner clearance with an offset calculator a mk2 can run 16 x 9 et15.
Imagine the axis about which your front wheel turns, in most cases a theoretical line running down through the centre of the wheel and tire. If you fitted spacers this line would no longer bet through the middle of the tire meaning you have changed the scrub radius. Not avdisable to change it majorly without thinking more about the effects.
Hope you're coming to the BBQ 9th of March.![]()
mk2 GTi 16v
Corrado G60
