Results 1 to 7 of 7
Thread: will these fit a mk6 gti
    Sep 2009
    blairmount/ nsw
    hi guys
    i bought a set of bbs rs861 wheels
    19in 9.5jj 52offset
    will these wheels fit onto a mk6 gti or am i going to have issues with them .
    RAZZ
    POLO,40MM JAMEX,PASSAT WHEELS-(5*112 TO 5*100),KILLER ICE SYSTEM
    MK6 GTI,LEATHER,MDI,WHEELS TO FOLLOW
    Apr 2008
    What's the PCD and centre bore?
    The width *may* be an issue.
    Nothing to see here...
    Nov 2005
    only way to find out is to test fit one on front and back and work from there
    dom
    Erskineville, NSW
    i doubt they will fit straight out the box.
    If the MKVI is anything like a base Octavia (6.5" / ET52) then 9.5" / ET52 (I assume 52 offset is the same as ET52) is 38mm closer to the strut. There's about 20mm to play with on a 6.5" rim IIRC, so you probably need around ET32. ET32 will give you an extra 38mm of outward poke - your wheel bearings will love you for that. /rolls eyes.
    i hope I'm wrong because they will look great if they fit.
    Erskineville, NSW
    There's about a knuckle width of space - call it 20mm. He'll have to run spacers - and then they'll poke like a mofo & scrape the guards unless the car is jacked up like a tractor.
    I had 17x8 ET35 on the Octy. Poke was as much as I was comfortable with and they could have gone another 15-20mm inwards, so a 9" rim at most on the front. The 9.5" may fit on the back.
    edit: what happened to thepost I was replying to?????
    Apr 2008
    Deleted by the poster.
    Erskineville, NSW
    Quote Originally Posted by Manaz View Post
    i hate that
