Results 1 to 3 of 3
Thread: Will these fit
    Will these fit
    Hi, really new to the VW scene and I want to pick up some wheels for the Golf IV.
    Found some with specs:
    16x7+33 16x8+33 5x114.3
    I intend on getting them re-drilled instead of adapters.
    Sep 2007
    what's the centrebore? most jap cars (that's the fitment) sometimes have too big a centrebore to redrill safely to 5x100.
    the rears will probably sit nearly flush and the fronts should only be about half an inch or so further out than stock.
    pixorban
    87' MK2 GTI
    13' MK7 TDI
    bumpy
    Got an email from RB wheels and he said the centre bore is around 60mm
    Should I still have them re-drilled? need hub ring and tuner bolts to run them?
    Cheers for the help
