thanks mate!
thats exactly what i needed
Go large or go home.
15 x 8 et0
Centres are G60 Corrado steelies.
Eastern Wheel works made them up for me. Wheel Repairs Melbourne
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
thanks mate!
Backspace is just half the entire width (edge-to-edge, not bead-to-bead) of the wheel + offset. So let's just say your wheel is 220mm wide, and you want an offset of ET18. That means you want a backspacing of 110mm + 18mm = 128mm.
Wheel builders generally prefer using the term backspacing because it's easier to work with.
ah rightio, cool. thanks for the info guys. makes more sense now
Do you mean half the rim or the tyre I guess talking about wheels it means the rim
In the link I posted it shows backspace as the distance between inside of face of hub to inner edge of rim
In that link you can compare two different rims and tyres and see exactly what the difference is.
