Where’s that quoted from?
Interesting to know, haven’t heard that before, guess the laws in SA are older since we don’t have RWC.
Also funny that you can buy new wheels as blanks and have them drilled to your desired stud pattern.
Update!
Just found this in some of my paper work & it's a Vehicle Standard's Document.
"The wheel must be one designed for the particular hub/axle in respect to bolt pitch circle diameter & wheel nut tapers. Wheel with slotted stud holes are not permitted."
Interesting quote, In the case of VW, off the shelf wheels generally don’t have ball seated holes, is it legal to change the bolts to match the wheels?
You are correct that many illegal items are available for purchase, so like anything it’s up to the user if they choose to run these modifications.
I never thought you guys cared so much about what is road worthy or "legal".
MK1 GLS 3door
A4 B7 2.0T
So what did they do to heat treat the wheels back to the original specification ???
Cast alloy ( and likely all alloy multi piece ) wheels are heat treated to give them the necessary strength, once welded , you kill the heat treatment in the weld HAZ, basically engineering in a weak point. The company that has done this would want a damned good lawyer, as in case of any event the owner of the vehicle, modifier of the wheel and the engineer who oversaw the process ( if there was one , doubtful ) would be up for some serious charges to answer, specially if a death has occured.
I have seen factory unmodified cast alloys break completely around the rim. ( into 2 round sections ) the guy was trying to sue GM for damages..
Fine if you need to modify the wheels, but do it in a safe engineered way, a wheel can be replaced a hell of a lot easier than a life...
Lots of MK 1 Scirocco's...
Cheers,
Grant...
mmm... i'm skeptical about widening alloys.
. . split rims ftw!!
87' MK2 GTI
13' MK7 TDI
