Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: Widening Alloys
  1. #21
    Sep 2005
    Where’s that quoted from?
  2. #22
    Quote Originally Posted by intensem1 View Post
    RWC book.
    I did have my ticket a while ago.
    You can also interperet a redrill as damage to a structural part of the rim & thus UnRWC.
  3. #23
    Sep 2005
    Interesting to know, haven’t heard that before, guess the laws in SA are older since we don’t have RWC.
    Also funny that you can buy new wheels as blanks and have them drilled to your desired stud pattern.
  4. #24
    Update!
    Just found this in some of my paper work & it's a Vehicle Standard's Document.
    "The wheel must be one designed for the particular hub/axle in respect to bolt pitch circle diameter & wheel nut tapers. Wheel with slotted stud holes are not permitted."
  5. #25
    Yes, but you can also buy lowered spring's & alot of other product's that make your car illegal too.
  6. #26
    Sep 2005
    Interesting quote, In the case of VW, off the shelf wheels generally don’t have ball seated holes, is it legal to change the bolts to match the wheels?
    You are correct that many illegal items are available for purchase, so like anything it’s up to the user if they choose to run these modifications.
  7. #27
    Feb 2007
    I never thought you guys cared so much about what is road worthy or "legal".
    MK1 GLS 3door
    A4 B7 2.0T
  8. #28
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by Spyda View Post
    Doesn't hurt to know.
    Just incase we're going for roadworthy. Or find little yellow stickers on our windows.
    i like volkswagens
  9. #29
    Perth. WA
    It has been done, this is what i found when searching few weeks back.
    Its totally illegal, after much searching and phonecalls, I came to realise that no one in Australia would do it.
    Every shop I called would say the same thing. If it fell apart, I could be killed (expecially if hurtling along at 120+MPH).
    A performance shop in Sydney was able to orchestrate the work for me though. I had to go through them, and from there I now know the wheels were shipped to Labrador, Queensland to be done.
    (You might be able to work out who might have done it, as I since have, but am not going to name the place publicly).
    I specified that I wanted to extend the 8" wheel to 9".
    I could have gone as large as I wanted. I was thinking about 9.5" but didn't want to have clearance issues.
    As the process only affects the inside of the wheel, not the hub placement, you will need some spacers. I had custom spacers machined up.
    As my inner edge was now 25.4mm closer to the strut, I had 15mm spacers made, and then had to subsequently machine the right hand side in to be a 12.5mm spacer to stop rubbing.
    Guards were rolled aswell.
    As stated elsewhere, it was about $700 for the widening and shipment of two wheels. (this included the costs of two 17" wheels being cut up aswell - remember you need 4 wheels to make 2 wider ones).
    About $700 for two Mickey Thompson 17" 275's and I think $80 for custom spacers. Plus associated fitment of rubber costs aswell.
    Not exactly a cheap process. You could probably get two second hand 17" 3-piece simmons and then have appropriate offset in the width youu want made for the same money.
    I however wanted to be stealth, so chose the same alloy rims that I drive around with everyday.
    The alloy rims are precision welded on both sides of the rim, and in reality should be bloody strong.
    I only got them for drag racing, so figured that in a straight line, they would be reasonably safe. I definitely wouldn't do circuit work on them - but I am a bit of a worrier
    The performance shop reckoned they would be fine to use as a daily driver, but the roads in sydney are so bad, i'd never chance it.
    I do however (on my two trips to the drags) put them on at home, and don't need to worry about changing tyres.
    So what did they do to heat treat the wheels back to the original specification ???
    Cast alloy ( and likely all alloy multi piece ) wheels are heat treated to give them the necessary strength, once welded , you kill the heat treatment in the weld HAZ, basically engineering in a weak point. The company that has done this would want a damned good lawyer, as in case of any event the owner of the vehicle, modifier of the wheel and the engineer who oversaw the process ( if there was one , doubtful ) would be up for some serious charges to answer, specially if a death has occured.
    I have seen factory unmodified cast alloys break completely around the rim. ( into 2 round sections ) the guy was trying to sue GM for damages..
    Fine if you need to modify the wheels, but do it in a safe engineered way, a wheel can be replaced a hell of a lot easier than a life...
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  10. #30
    Sep 2007
    mmm... i'm skeptical about widening alloys.
    . . split rims ftw!!
    87' MK2 GTI
    13' MK7 TDI
