Page 12 of 13 FirstFirst ... 210111213 LastLast
Results 111 to 120 of 126
Thread: Which wheels will fit
  1. #111
    Quote Originally Posted by GregC View Post
    hi there just bought a T4 Dual Cab and looking for wheels and tyres to go with it. The previous owner fitted 19 inch mags to it and it looks great but is not legal. I am after something that is around 17 inch and load rated. Any hints? Even thought about steel wheels with moon caps on them. All answers gratefully accepted
    Greg
    there is often some 17" steelies off a T4/transporter floating around ebay, not sure if all the vw commercial range have the same stud pattern / specs though...?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  2. #112
    May 2011
    Just thought I would post the size/specs of wheels fitted to my R36 (5x112).
    Standard are: 18x8, 44 offset, 235/40/18.
    Recently fitted: 20x8.5, 42 offset, 245/30/20.
    Fills the guards nicely with no rub, even with 3 people in the back. Would not go less than 40 offset though if you 8.5inch as feel the tyre would then rub on the outer guard.
  3. #113
    Jan 2012
    australia
    What is the offset for 06' polo gti? What are the biggest u can put in without it rubbing?? With stock suspension.
  4. #114
    Oct 2010
    Melbourne, VIC
    Check the 9N(3) subforum
    Resident grumpy old fart
  5. #115
    Gold Coast
    Actually, maybe this should have gone on this thread instead!
    I was looking around for original wheel sizes, and found this link:
    Watercooledwheels
    and this one for mods:
    http://blog.swdubs.co.uk/05/2011/mk1-wheel-size/249
    good info for a noob like me!
    ---------- Post added at 11:22 AM ---------- Previous post was at 12:18 AM ----------
    found an even cooler tool!
    Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
    Dan P
    1983 Mk1 Golf GTI Cabriolet
  6. #116
    Quote Originally Posted by BlueGti View Post
    there isnt an offset as such for a car... would be a standard range (et35-43 for example). but you'd be best to refer to the standard wheels on your car. also need to check the width as width and offset means nothing without the other.
    biggest id imagine you could get some 19s or 20s, but as any of the polo guys will tell you that'd just be stupid. it all comes down to tyre size. id imagine 16-17 is idea, with some 18s workable.
    Quote Originally Posted by danpez View Post
    Watercooledwheels
    Mk1 Wheel Size? | SWDubs Blog
    that last link was a good one until they started making people pay...
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  7. #117
    Dose any one have any pics of a mk2 gti 4door with simmons v4 15" on there? want to get an idea what the car will look like before i buy the wheels..
    Thanks
  8. #118
    Quote Originally Posted by hamza View Post
    Thanks
    http://www.vwwatercooled.org.au/foru...e-68531-2.html
    lots of cars in this thread with similar looking wheels
    EDIT: oh thats your thread
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  9. #119
    yep it is...
  10. #120
    Jan 2012
    HELP! I have a MY2011 Golf Comfortline fitted with the standard 16" Cleveland alloy wheels and space saver spare. I have obtained a Cleveland alloy wheel to use as the spare wheel with the following markings:
    6.5J x 16H2ET50
    AISI7Mg
    1K0601025AJ
    !331
    Another stamp says that it is made RONAL made in Mexico with a date stamp 29.05.06 and something that looks like 9.0 II : II
    What do the above codes mean? Will this wheel fit my 2011MY Golf Comfortline? What other VW models will it fit?
    Thanks for your help.
Similar Threads
  1. wheels Mark V TDI
    By Rod_H in forum Wheels & Suspension
    Last Post: 18-01-2007, 04:06 PM
  2. Wheels for my MK2
    By MK2 GTI in forum Wheels & Suspension
    Last Post: 03-12-2005, 09:38 PM
