Page 8 of 13 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 126
Thread: Which wheels will fit
  1. #71
    Sep 2009
    blairmount/ nsw
    wheels that fit
    i have fitted a set of 5x112 passat wheels on my 5x100 polo
    as long as the wheel has a center cap cover and enough body to be re-drilled of filled and then re-drilled you can fit an array of wheels on your car
    center bores can be machined
    off sets can be cut or spacers can be added ( im not a fan of spacers )
    i have done alot of this in the past
    xr4 wheels = 4x108 : re done to 4x100 for a golf 1
    alfa oz racing = 5x98 : re- done to 5x100
    email if any one needs help with this
  2. #72
    S.E Melbourne
    anyone know what stud pattern a BMW 2500 would have?
    It doesn't matter what car you drive.. If you're a complete wanker.. People still won't want to talk to you..
  3. #73
    Sep 2006
    West Sydney
    BMWs have either been 4x100 or 5x120, and a quick google image search shows they're 5 stud. My assumption is they're 5x120.
  4. #74
    Aug 2009
    What are the chances of fitting 7" and 8" wide Subaru offset (+50 or so) wheels within the guards of my VR6 (with spacers, 20mm or thereabouts)?
  5. #75
    Sep 2007
    7" with an equivalent offset of 30+ will fit easily front and rear. i'm not too sure about 8" with 30+ offset. there might not be enough rear clearance to the strut, or you wont be phat enough!!
    wheel centre bore is also too small.
    87' MK2 GTI
    13' MK7 TDI
  6. #76
    Aug 2009
    Not stock Subaru wheels! Hells no! Just aftermarket (Volk) wheels that are suited to a Subaru application.
    I will probably roll phat and deep, maybe pulled/flared guards and anything else to get my wheels under the guards.
    It will potentially be extreme. I aint scared to get real about stance.
  7. #77
    Point Cook, Vic
    Quote Originally Posted by IH8 View Post
    im running 16x7.5" ET35 on my VR6. Front fits fine. Rear is a little tight for inner clearance to my coilovers so im running an 8mm spacer. Might be different with other suspension setups though. No scrubbing or guard rolling.
    FOLLOW US ON FACEBOOK
  8. #78
    Oct 2006
    Does anybody know if these would fit? Would need adapters but the offset makes me think its a no go
    http://cgi.ebay.com.au/VW-BRM-Alloy-...d=p3286.c0.m14
    would look filth on a MK1 i reckon
    also how do u rename a link? a noob question i know
  9. #79
    S.E Melbourne
    you could fit them with adapters and hub rings, don;t know how they will sit though more than likely be poking a fair bit.
  10. #80
    Mar 2009
    http://cgi.ebay.com.au/4-X-WHEELS-OF...#ht_500wt_1182
    just wondering if there would fit on a mk3?
    i know i can bore out the centre hub to 57.1, im just not too sure on the offset...
Similar Threads
  1. wheels Mark V TDI
    By Rod_H in forum Wheels & Suspension
    Last Post: 18-01-2007, 04:06 PM
  2. Wheels for my MK2
    By MK2 GTI in forum Wheels & Suspension
    Last Post: 03-12-2005, 09:38 PM
