anyone know what stud pattern a BMW 2500 would have?
i have fitted a set of 5x112 passat wheels on my 5x100 polo
as long as the wheel has a center cap cover and enough body to be re-drilled of filled and then re-drilled you can fit an array of wheels on your car
center bores can be machined
off sets can be cut or spacers can be added ( im not a fan of spacers )
i have done alot of this in the past
xr4 wheels = 4x108 : re done to 4x100 for a golf 1
alfa oz racing = 5x98 : re- done to 5x100
email if any one needs help with this
BMWs have either been 4x100 or 5x120, and a quick google image search shows they're 5 stud. My assumption is they're 5x120.
What are the chances of fitting 7" and 8" wide Subaru offset (+50 or so) wheels within the guards of my VR6 (with spacers, 20mm or thereabouts)?
7" with an equivalent offset of 30+ will fit easily front and rear. i'm not too sure about 8" with 30+ offset. there might not be enough rear clearance to the strut, or you wont be phat enough!!
wheel centre bore is also too small.
87' MK2 GTI
13' MK7 TDI
Not stock Subaru wheels! Hells no! Just aftermarket (Volk) wheels that are suited to a Subaru application.
I will probably roll phat and deep, maybe pulled/flared guards and anything else to get my wheels under the guards.
It will potentially be extreme. I aint scared to get real about stance.
Does anybody know if these would fit? Would need adapters but the offset makes me think its a no go
http://cgi.ebay.com.au/VW-BRM-Alloy-...d=p3286.c0.m14
would look filth on a MK1 i reckon
also how do u rename a link? a noob question i know
http://cgi.ebay.com.au/4-X-WHEELS-OF...#ht_500wt_1182
just wondering if there would fit on a mk3?
i know i can bore out the centre hub to 57.1, im just not too sure on the offset...
