anyone know what stud pattern a BMW 2500 would have?
i have fitted a set of 5x112 passat wheels on my 5x100 polo
as long as the wheel has a center cap cover and enough body to be re-drilled of filled and then re-drilled you can fit an array of wheels on your car
center bores can be machined
off sets can be cut or spacers can be added ( im not a fan of spacers )
i have done alot of this in the past
xr4 wheels = 4x108 : re done to 4x100 for a golf 1
alfa oz racing = 5x98 : re- done to 5x100
email if any one needs help with this
BMWs have either been 4x100 or 5x120, and a quick google image search shows they're 5 stud. My assumption is they're 5x120.
What are the chances of fitting 7" and 8" wide Subaru offset (+50 or so) wheels within the guards of my VR6 (with spacers, 20mm or thereabouts)?
7" with an equivalent offset of 30+ will fit easily front and rear. i'm not too sure about 8" with 30+ offset. there might not be enough rear clearance to the strut, or you wont be phat enough!!![]()
wheel centre bore is also too small.![]()
87' MK2 GTI
13' MK7 TDI
Not stock Subaru wheels! Hells no! Just aftermarket (Volk) wheels that are suited to a Subaru application.
I will probably roll phat and deep, maybe pulled/flared guards and anything else to get my wheels under the guards.
It will potentially be extreme. I aint scared to get real about stance.
Does anybody know if these would fit? Would need adapters but the offset makes me think its a no go
http://cgi.ebay.com.au/VW-BRM-Alloy-...d=p3286.c0.m14
would look filth on a MK1 i reckon
also how do u rename a link? a noob question i know![]()
http://cgi.ebay.com.au/4-X-WHEELS-OF...#ht_500wt_1182
just wondering if there would fit on a mk3?
i know i can bore out the centre hub to 57.1, im just not too sure on the offset...
