Skyline has a 66mm centre bore
Printable View
5 stud (5x114.3) - Skylines are 5 stud whereas Silvias are 4-stud right?
Anyway, thanks for the info evorobin - do you think a 100mm PCD can be drilled on 60mm+ centrebore?
Should be easy upto 66mm but without seeing a picture it's hard to tell.
Yeah, I'm considering buying a set of wheels for later - I've requested pictures but don't know if I'll get a reply. Just that I had a similar set of wheels before (5x114.3, ~70mm centrebore) and I couldn't get them redrilled as the centrebore was too big. I don't want to make the same mistake twice.
(You've probably guessed it... yep they're BBS RS - I don't know why I bother sometimes?)
I got them on at last. see signature for pic. Some miror scrubbing on HARD cornering but stiff shocks and spring change will fix that - we think.
The tyres are 16x205 40 series on the front and 16x205 45 series on the back.
Had to take the calipre bracket back a matter of 2 or 3 mm.
Have just fitted my 14" Golf Mags on a 95 Charade so assumedly it goes the other way? Have fitted new 16" Borbets
Does anyone know the PCD from a Datsun 1200, 1600, 180B etc??
also what's the go with multi stud wheels? IS it just like having two PCD on the middle?? ANd can this be done to any wheel?
if so, where and how much??
can any one clarify for me??
