Page 10 of 13 FirstFirst ... 89101112 ... LastLast
Results 91 to 100 of 126
Thread: Which wheels will fit
  1. #91
    Sep 2009
    Five Dock
    hey peoples,
    will holden 2008 commodore SS rims fit a 2009 VW TRansporter? The STud Patterms are the same and the offsets are off by 7mm... will this make a huge difference when fitting?
  2. #92
    Jan 2011
    Hey all.. hope this is the right spot to put this is..
    Ive got a set of BBS Style 5's (off a bmw 5 series) the size is 17x8 and 17x9 et20(i think)
    With a 20mm adapter, will this fit my VW MK4 golf fine? or would it need work?
    cheers
  3. #93
    Feb 2009
    NSW
    My understanding is: Add adapters, You lose et, so you'd end up at 0 offset.
    The style 5's wouldn't work unless it was an E36 version as they had a higher offset usually around the high 30's. 5 Series have lower offset.
  4. #94
    Jan 2011
    Quote Originally Posted by ozgti View Post
    Thanks for the reply... the exact specs are
    8"x17", 20mm
    9"x17", 22mm
  5. #95
    Quote Originally Posted by hazjaz View Post
    8"x17", 20mm
    9"x17", 22mm
    Late reply, but way to aggressive for a mk4, those specs before adding adpater width would be great though!
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  6. #96
    Jan 2011
    Porsche Boxster Spyder wheels
    Hey Guys,
    Does anyone know whether Porsche's lightest wheels from Sypder will fit on a Golf R??
    Cheers..
  7. #97
    Quote Originally Posted by reddc5r View Post
    Hey Guys,
    Cheers..
    What are the specs on said wheels? I believe all porshce wheels are 5x130 pcd, and arnt the R's 5x112? in which case no, they wont fit
    BUT Porshce are generally adapter friendly though, so you could try that keeping in mind adapters are illegal of coarse.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  8. #98
    Jan 2011
    I'm not sure if the R pcd is 5x112..can someone who knows pls confirm?? Porsche is 5x120 I believe.
  9. #99
    Dec 2007
    Ipswich....Home of the original Bogan!
    OK been looking through and searched... will 18X8 WITH A 45+ OFFSET 5/100 fit MK4 GTI
    Tazz
    01 Golf GTI
    95 Golf Cab
    67 Type3 Fastback (Kermit)
    62 Type3 Square
  10. #100
    Quote Originally Posted by Tazz View Post
    Tazz
    I had those specs on my bora, was ok until i lowered it on coilovers. i was JUST rubbing on the strut. 5mm spacers fixed it, but even a 3mm would have been ok id imagine. maybe go for something like 8" wide with et35
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
Similar Threads
  1. wheels Mark V TDI
    By Rod_H in forum Wheels & Suspension
    Last Post: 18-01-2007, 04:06 PM
  2. Wheels for my MK2
    By MK2 GTI in forum Wheels & Suspension
    Last Post: 03-12-2005, 09:38 PM
