hey peoples,
will holden 2008 commodore SS rims fit a 2009 VW TRansporter? The STud Patterms are the same and the offsets are off by 7mm... will this make a huge difference when fitting?
Printable View
hey peoples,
Hey all.. hope this is the right spot to put this is..
Ive got a set of BBS Style 5's (off a bmw 5 series) the size is 17x8 and 17x9 et20(i think)
With a 20mm adapter, will this fit my VW MK4 golf fine? or would it need work?
cheers
My understanding is: Add adapters, You lose et, so you'd end up at 0 offset.
The style 5's wouldn't work unless it was an E36 version as they had a higher offset usually around the high 30's. 5 Series have lower offset.
Hey Guys,
Does anyone know whether Porsche's lightest wheels from Sypder will fit on a Golf R??
Cheers..
OK been looking through and searched... will 18X8 WITH A 45+ OFFSET 5/100 fit MK4 GTI
Tazz
