Results 1 to 6 of 6
Thread: Wheels sizes?...
    Dec 2005
    Wheels sizes?...
    Could someone please explain what the different numbers for wheel sizes are..... I know about tyre sizes, but this offset, 4 x 100 studd pattern etc.. is very confusing
    cheers
    Lee
    would the wheels below fit a golf?
    15 X 6.5
    4 STUD DUAL FITMENT
    100/4
    OFFSET +40
    sydney
    yep they will fit (pcd 4x100 is good for mk1 2 and half of 3)but the offset being 40 (the et) means they will be quite close to the strut tower
    rule of thumb the higher the offset the closer the wheels will be towards the centre of the car the lower the offset and (then negative)the further out into the arches of the car.
    from memory golf standard et is like 38 or something ,
    another thing to check is the centre bore which from memory is 58mm , bigger is ok (spacer rings can be used)but smaller requires a trip to the machinists
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    Jul 2005
    Melbourne, Williamstown
    Centre bore is 57.1mm, I learnt the hard way. :roll:
    Spent $250 getting my new wheels machined(to 57mm) and then the excitement of new tyres on them. Come time to fit them on the car and they don't fit.
    mk2 GTi 16v
    Corrado G60
    Dec 2005
    My VW rabbit service manual says the standard offset is 45. Could be different for the Aus delivered golf.
    syncro Guest
    The offset will be different with the width of the wheel.
    There were two different wheels sold in Australia, LS,GLS and a narrower one for the GLD.
    Mk4
    I've got a Mk4 '00 GTI 5dr
    what do i need to take into account whan looking for new rims?
    N MY 18T -- '00 Golf Mk4 1.8T GTI
Similar Threads
  1. wheels Mark V TDI
    By Rod_H in forum Wheels & Suspension
    Last Post: 18-01-2007, 04:06 PM
  2. Wheels for my MK2
    By MK2 GTI in forum Wheels & Suspension
    Last Post: 03-12-2005, 09:38 PM
