yep they will fit (pcd 4x100 is good for mk1 2 and half of 3)but the offset being 40 (the et) means they will be quite close to the strut tower
rule of thumb the higher the offset the closer the wheels will be towards the centre of the car the lower the offset and (then negative)the further out into the arches of the car.
from memory golf standard et is like 38 or something ,
another thing to check is the centre bore which from memory is 58mm , bigger is ok (spacer rings can be used)but smaller requires a trip to the machinists
